87 c-10 fuel selector valve with efi ?
so this 87 was tbi 305 and now a hopped up 350 with aftermarket efi 56-58psi range .
does anyone know if the stock tbi selector valve can handle the psi of around 60 or is there a better one . if its to crazy i will just do 1 efi tank and acdelco ep381 pump and be done with it . then use second tank as a transfer tank to the efi tank .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Re: 87 c-10 fuel selector valve with efi ?
The stock selector valve will not work from my reading, you will need something like this: http://products.pollakaftermarket.co...r-driven-valve to handle the pressure along with efi sending units and pumps
