Old 04-03-2018, 01:09 PM   #1
davepl
davepl's Avatar
Has anyone seen the 4L80E speed tailhousing?
When I put a 4L80E in my truck i was confronted with the common problem of it not having a speedo output, so I use the electronic box that spins the cable for me driven by the TCM computer. I don't care for it, it's a little noisy and the cable bounces.
I should have done the 4L80E tailhousing with the speedo provision, but it was $695 for a tailhousing!
I'm just wondering if anyone owns one or is familiar with it. I'd hate to choke down that price only to find out it's not a nice piece!
Here's a link: https://transmissioncenter.net/shop/...iABEgJxyvD_BwE
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-05-2018, 01:57 PM   #2
4x4k30
4x4k30's Avatar
Re: Has anyone seen the 4L80E speed tailhousing?
what year is your transmission ? I was thinking that most of the 4l80e already have a the vss switch in them.. if I remember my 06 4l80 it was a 2wd and I took off the rear tailhousing and it didn't have the switch in it .see the pic at the back side of the drivers side rite above the round wire harness hookup
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 04-05-2018, 02:04 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
4x4K30 I think your confusing it with the NSS switch. The VSS sensor is the thing your showing, but The thing the OP is referring to is a provision for cable-driven speedometers on our older trucks. The 4l80e never had (unless maybe in some fleet application I haven't seen) a factory gear/cable speedo drive. He's currently using the drive box (Cable-X?) to convert the factory VSS/OSS signal into a little servo motor which drives the cable speedo.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-05-2018, 02:50 PM   #4
davepl
davepl's Avatar
Bruce (?) is right, I'm speaking of the tailhousing with the provision for installing gears and connecting a mechanical (cable) speedometer, which was never offered stock. That's why it's so expensive... $50 for a TH400 and $695 for this one!
Old 04-05-2018, 02:56 PM   #5
4x4k30
4x4k30's Avatar
yes I am confused when I swapped in my 6.0 and 4l80e in my 77 I don't remember the tail housing having any switches in it. the transmission was a 2wd and I removed the tail housing only and cut off 2 inches of the rear out put shaft to bolt up the 205 . now I just put a 6.0 in my 79 and I am using a turbo 400 and I thought the vss switch was just used for the electric speedometers. but I have read that you do need to use it for the engine to operate correctly so I guess I will just get a vss inline speed-o and use it since they are not expensive.
Old 04-05-2018, 03:06 PM   #6
4x4k30
4x4k30's Avatar
ok I was confused I just never did know everything about the vss when I swapped the 6.0and 4l80 in to my 77 it was all hooked together when I dropped it in .. so when I put just the 6.0 in my 79 with the turbo 400 I thought I didn't need to worry about the vss
Old 04-05-2018, 03:08 PM   #7
72MARIO
72MARIO's Avatar
Dave what brand of cable converter did you use ?
We used this one http://www.shiftworks.com/tailhousing.htm on my dads truck it was junk gears did not fit properly and it took a day in the shop to make it work. Were in canada so that price is closer to a $1000.00 Canadian once you get it in your hands your better off buying a electric cable box.
https://www.speedhut.com/ecommerce/p...peed-Converter
or
http://www.dakotadigital.com/index.c...rod/prd886.htm
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-05-2018, 03:28 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Who the F*ck is Bruce? lol My username is "Brew City".
Everyone knows me as Rev Jay (or Reverend Jay if you like titles). Jay is also fine.
There isn't anything to see in the housing in stock form. The device in question adds those parts in, and requires a modded shaft. Its a really expensive solution, but no one really has a better option for the 80e's.
Old 04-05-2018, 04:34 PM   #9
mongocanfly
Post Whore
mongocanfly's Avatar
I used the dakota digital convertor box in mine. ..there's no noise and no bounce...it could be the cable between the box and speedo needs lubed....mine works great and I wouldn't hesitate to use another one...and am fixing to on my current project. ...I have my box mounted under hood so that may make some difference..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
mongocanfly is online now   Reply With Quote
Old 04-05-2018, 05:36 PM   #10
davepl
davepl's Avatar
Yeah, I didn't do mine, the guy who installed the trans did. Nice tidy work but he mounted the box under the dash and the cable has a bendy path I don't care for. I should try just a long cable in a loop and see if it helps.
