Old 04-03-2018, 06:14 PM   #1
Big Daddy Bear
Big Daddy Bear's Avatar
Help with some RPO codes please...
I have managed to find all but the 5 circled. If anyone can help, I would appreciate it.
1992 Chevrolet 1500 W/T:
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
Old 04-03-2018, 06:21 PM   #2
mountie
mountie's Avatar
Re: Help with some RPO codes please...
The dealership could help you with that....
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
Old 04-03-2018, 06:27 PM   #3
Big Daddy Bear
Even on a truck this old??
Old 04-03-2018, 08:04 PM   #4
mountie
mountie's Avatar
they are terrible when it comes to GM parts, but they should still have numbers they can look up?
Old 04-03-2018, 08:11 PM   #5
Big Daddy Bear
Okay thanks, may give it a try.
Old 04-03-2018, 08:39 PM   #6
Kudzupatch
Kudzupatch's Avatar
Google is your friend
http://d354nuoz4t18d4.cloudfront.net...?cb=1497380755
Kudzupatch is offline   Reply With Quote
Old 04-03-2018, 08:49 PM   #7
Big Daddy Bear
Originally Posted by Kudzupatch View Post
I had used this one:
http://www.rpocodes.com/GM-RPO-codes...0through4.html
It seemed pretty complete, but those 5 were not included.
I like your option much better!!! Thanks!
Old 04-03-2018, 09:06 PM   #8
Pampas56
After a quick google search I found this:
YET is 225/75/15 rear tires
ZET is 225/75/15 spare tire
1SA is Option package 01 what that entails is anybody's guess.
6WK and 7WK are Computer selected Suspension LH and RH respectively. I would guess that the factory groups the suspension parts by size or rate and tries to match the components (kinda like piston weights for high performance engines).
Keith Seymour should have the definitive answer over on the square body forum.
1989 Silverado K2500ECLB- 307K miles with 90 K TBI 350-Not a show truck, a work tool that I can drive!
1992 K1500 ECSB- 190K miles- I guess I'm just a truck guy now!
Pampas56 is offline   Reply With Quote
Old 04-03-2018, 09:59 PM   #9
Big Daddy Bear
Thank you, curiosity satisfied!!!
Old 04-04-2018, 11:28 AM   #10
Keith Seymore
Keith Seymore's Avatar
This is correct.
That means XET is 225/75 15 front tires. They are divided up that way in case somebody wanted to get street tires on the front, snow tires on the rear and a different spare.
Generic Info packet from the GM Heritage Center archive is attached. 1SA is the "quick spec" in the dealer order guide. The info packet doesn't call it out the same way but since it is a Work Truck you have a pretty good idea of the content anyway.
https://www.gmheritagecenter.com/doc...olet-Truck.pdf
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-04-2018, 11:36 AM   #11
Big Daddy Bear
Thanks!
Old 04-04-2018, 11:54 AM   #12
mountie
mountie's Avatar
I wonder if Chevrolet & my GMC share the same codes? They only show a Silverado.
Old 04-04-2018, 03:55 PM   #13
Pampas56
Originally Posted by Keith Seymore View Post
This is correct.
K
Thanks for tapping in Keith.
I noticed that there were a large number of suspension RPOs, all LH or RH. Is my supposition correct or even close to the case?
Or is it just covering Berettas on up to K3500 springs?
Old 04-04-2018, 08:26 PM   #14
Keith Seymore
Yes. A GMC was a Chevy with RPO Z88.
They went down the same assembly line. Sometimes they were a Chevy on one side and a GMC on the other.
K
1979-1986
1986 - 2019
Old 04-04-2018, 08:28 PM   #15
Keith Seymore
No - you were exactly correct. The buyer chooses a model (and/or GVW) and the computer picks the right springs based on the engineering release tables.
K
1979-1986
1986 - 2019
Old 04-04-2018, 10:03 PM   #16
mountie
mountie's Avatar
Interesting..... about springs..... My factory leaf springs ( C2500 / 7200 )
..... The left spring was built differently from the right side leaf.
The dealer could not explain it.
Old 04-05-2018, 12:40 AM   #17
Mr_Rich
Mr_Rich's Avatar
I think it has to do with axle torque. Sometimes the vehicle would "shudder" on takeoff when the springs are equal. Another reason why the shocks were staggered too.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
