Old 04-03-2018, 08:29 PM   #1
collin70k/20
collin70k/20's Avatar
Dash light help
Hey guys on my way home from work one day I lost my dash lights and side marker lights in my 1970 k/20. But I still had headlights. Thought it was the fuse. Wasn’t blown but I replaced it anyway and it did nothing. Was wondering where to start, thanks for any help, Collin
1970 Chevy K/20 truck 350 4 speed. Soon putting in a mild built 400 small block.
My daily 1970 k20 - http://67-72chevytrucks.com/vboard/s...=1#post7568564
collin70k/20 is offline   Reply With Quote
Old 04-03-2018, 09:10 PM   #2
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Dash light help
most guy will say change the head light switch its the main thing that connects everything.Go buy a new one.
Yes people say i hate throwing parts at my trucks but its a given
stsalvage is offline   Reply With Quote
Old 04-03-2018, 09:39 PM   #3
87Skier
87Skier's Avatar
Re: Dash light help
That's where I would start. If you have time, you could make sure that your headlight switch is supplying power to the proper wiring.
If you want to test it, you should have 12 volts at these points:
At the cluster: Gray wire is illumination (from fuse panel)
At the switch:
Dark green is cluster lights (goes to fuse panel)
Brown are running lights
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 04-03-2018, 10:04 PM   #4
harpo231
harpo231's Avatar
Re: Dash light help
Check ground.....
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 04-04-2018, 09:13 AM   #5
collin70k/20
Re: Dash light help
Ok thanks guys for the help. I just ordered a switch and will get power supply’s and the grounds.
