Old 04-03-2018, 09:58 PM   #1
Jotto82
High Rise Intake Edelbrock 7101
Being offered a high rise intake. Edelbrock 7101. My motor is completely rebuilt with new stock parts. Maybe 10k on it. I have a 650 Holley on it now. Can anyone tell me if this will be compatible as a “bolt on addition” Or will I need to do some other work on it to have the truck run decent? Runs excellent now. I do want to add hp, would this be a good piece to add?
Jotto82 is offline   Reply With Quote
Old 04-03-2018, 10:05 PM   #2
GSP7
GSP7's Avatar
Re: High Rise Intake Edelbrock 7101
https://www.summitracing.com/parts/e...SAAEgIoYfD_BwE
Edelbrock Performer RPM intake manifolds have a high-rise, dual-plane design. They produce incredible top-end horsepower, while retaining good throttle response. Performer RPMs have larger plenums and runners to match the free-flowing exhaust, high-lift cams, and other modifications of a high-output engine. They're intended for high performance street or competition engines that run from 1,500 to 6,500 rpm.
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 04-04-2018, 12:50 AM   #3
Jotto82
I did look the part up. More curious if I can just add it and be done or if I’m going to have to buy more parts to make it functional
Old 04-04-2018, 07:51 AM   #4
sweetk30
sweetk30's Avatar
nothing is ever bolt on . . . .
and thats more a mid to upper end intake .
to get upper power you loose a little lower end . . . and vise versa .
our big heavy trucks need lower end and torque to get them rolling .
good old saying : torque gets you rolling and horse power keeps you rolling .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 04-04-2018, 11:25 PM   #5
Jotto82
Sounds like at this point it not a good addition. I truly just don’t know what works and what does
Old 04-04-2018, 11:41 PM   #6
69heavychevy
69heavychevy's Avatar
If your block is 86 or older then it will "bolt on", but like mentioned before it probably wouldn't benefit your stock engine very much. A 2701 would be a better choice.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 04-05-2018, 12:54 AM   #7
hans2
Performer RPM is an excellent manifold, but not my first choice for a stock 350 rebuild. Plenum volume and runner cross section are both a bit on the large side for that application. You'll notice a slight decrease in off-idle torque compared to either the stock iron or Performer (2101) manifold, but possibly slightly more power in the mid-upper rpm ranges.
With stock internals, the stock iron unit is pretty tough to beat, but a 2101 Performer can give it a little bump in the midrange without sacrificing power down low.
hans2 is offline   Reply With Quote
Old 04-05-2018, 07:09 PM   #8
Jotto82
I want to get to 400+ HP. It’s really hard not knowing which way to go. I should probably just buy a kit for the top end and be done with it.
