Old 04-03-2018, 10:17 PM   #1
Mr. M3
77 C30 crew Dually trans swap questions
Currently the truck has a 454 paired to a TH350, my main question is what are your thoughts on putting a 700R4 behind the 454? Keeping in mind this is by no means a speed application, more for heavy loads and towing. The second question being more towards the drive shaft length, will I need to chop the shaft down? I will need a new yoke for sure if I am understanding it correctly (27 teeth vs 30 on the spline).
Thanks in advance for any input!
1988 Suburban V10 350 TBI
1969 C10 Stepside inline 6 250 (new project)
1977 C30 3+3 Camper special 454
Mr. M3 is offline   Reply With Quote
Old 04-03-2018, 10:49 PM   #2
sweetk30
sweetk30's Avatar
Re: 77 C30 crew Dually trans swap questions
700r4 + 454 + heavy towing loads = DEATH FAST
and its 27 spline or 32 spline on the outputs for gm of our vintage .
if you want beefy its th400 or 4l80-e . and the 4l80-e needs a controler to run it . look these guys up . www.usshift.com great price point and tons of softwear options to play with .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 04-04-2018, 12:49 AM   #3
bilfman
bilfman's Avatar
4L80e is the way to go, it’s basically a th400 with overdrive. The electronics are easy with an aftermarket controller. I have a build here in the forums.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
