Old 04-04-2018, 12:32 PM   #1
brown7373
brown7373's Avatar
1972 Cheyenne C10 Ground Straps
Did the 72 with 350 use engine ground straps? When I pulled the engine, I didn't find any grounds. If yes, where did they attach and how many. I thought I had seen the rear of the heads attaching to the firewall, but I can find no documentation of that.
brown7373 is offline   Reply With Quote
Old 04-04-2018, 02:33 PM   #2
sick472
sick472's Avatar
Re: 1972 Cheyenne C10 Ground Straps
I can tell you that my 72 with a 350 had at least two ground straps when I pulled the motor, but I can not tell you where they go, it's been too long since. My guess is one goes to the firewall and the second goes to the frame, but where exactly - I don't recall.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 04-04-2018, 02:37 PM   #3
68 P.O.S.
The negative battery cable goes to the passenger side head and there's 2 ground straps that go from the firewall to the rear of the valve cover on each head
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 04-04-2018, 03:15 PM   #4
superhondaz50
superhondaz50's Avatar
Yup
-Battery to engine block
-2 from heads to firewall
-passenger fender to frame (I also use a core support to frame)
-passenger cab mount to frame
-bed to frame
superhondaz50 is offline   Reply With Quote
Old 04-04-2018, 03:45 PM   #5
demian5
demian5's Avatar
Originally Posted by superhondaz50 View Post
Yup
-bed to frame
Also:
- Battery to passenger fender (almost all GM truck have this).
- Driver side of the engine to the frame
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-04-2018, 05:42 PM   #6
68 P.O.S.
To clarify on the battery cables, both have a 2nd smaller wire that comes off of them. Not sure if this applies to all years or not, but the smaller negative cable wire attaches to the core support. On my 72 specifically, it attaches to the same bolt behind the battery box that's used to ground the headlights. The smaller wire on the positive cable goes to the junction box on the passenger fender with a fusible link. Here's a good thread with pics of all the original ground locations. http://67-72chevytrucks.com/vboard/s...d.php?t=487363
Old 04-04-2018, 05:49 PM   #7
demian5
demian5's Avatar
Double check that link.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-04-2018, 06:22 PM   #8
68 P.O.S.
Oh jeez, thanks man. Take 2 http://67-72chevytrucks.com/vboard/s...d.php?t=422234
