Vent door seal
I need a new seal for the driver's side vent door that is located in the kick panel. The door works properly, but the seal is crumbling. I looked at Brother's, and found only the whole door. I could not find anything at LMC. Does anyone know of a source?
Active Member
![]() Join Date: Mar 2018
Re: Vent door seal
Previous C10's 69 SB CST - sold 72 Cheyenne Super LB - sold |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Vent door seal
Board vendors Classic Heartbeat and GMC Paul carry these as well.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
Re: Vent door seal
Thank you!
Re: Vent door seal
I just cut my own out of an inner tube. Probably not "correct" but function is good and it's cheap.
Re: Vent door seal
At this point I'm going to give a BIG thumbs up to Classic Heartbeat.
I made an order thru them, and an order thru Brothers at about the same time. Classic Heartbeat is farther away from me than Brothers, but they got the order to me faster, and cheaper than Brothers did. The Classic Heartbeat box was probably 5x the size of the Brothers box yet shipping was significantly cheaper. Probably because Brothers pads their "cheap" prices with extra shipping and handling charges. Also, the Brothers order came in wrong. Now over a month later the correct part they said they shipped has still not arrived. Classic Heartbeat 1, Brothers 0 |
Re: Vent door seal
I went through the trouble of replacing my vent window seal only to find out that the seal was too thick to close correctly. They dont cost much, but it was very time consuming and a waste. If I were you, I would only take a suggestion from someone who has actually done it; no offense to the vendors out there.
USCG "Support Search & Rescue, Get Lost" |
Re: Vent door seal
... and if you find one that works, let me know.
Carpe manana
Re: Vent door seal
Mine were recently replaced for the blue blazer build - I haven't confirmed fitment yet but the seals didn't strike me as off much in terms of thickness.
Re: Vent door seal
Deadhead,
Since you already have them installed can you test it out and give us a report.
Carpe manana
Re: Vent door seal
Will do. These are at the resto shop w the blazer. I hope to get by next week. Pete
Re: Vent door seal
I located my vent seals at classicparts and mine were I think a little thicker, hard to tell when the originals were nonexistent, but they serve their purpose and I can close mine to where no air leaks through.
Posted via Mobile Device |
#13 |
Re: Vent door seal
No one else wants to chime in on this one?
#14 |
Re: Vent door seal
I did the one in my Burban with seals from Classic Parts. Small write up here post 232
http://67-72chevytrucks.com/vboard/s...698377&page=10
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#15 |
Re: Vent door seal
That's a interesting discussion about the seals on page s 2 and 3. I had a similar problem and was too upset to contact the vendor to resolve the issue. Maybe its a character fault of mine, but sometimes I just want things to work/fit like they're suppose to. just thinking about it now gets me
. At some point in the future I'll have to tackle it again...
#16 | |
Re: Vent door seal
Great DIY
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#17 |
Re: Vent door seal
Finally found the material for the in cab air vents. I did this because I could not find a “full” piece, the material is G. M. certified for gaskets, I WANT IT THE WAY THE FACTORY MADE IT, not with the middle cut out, the way all aftermarket are made! Bought enough to make lots of gaskets. In the next week or so will make one and fit it to see how it works.
#18 | |
![]() Join Date: Feb 2010
Re: Vent door seal
#19 | |
Re: Vent door seal
#20 | |
Re: Vent door seal
#21 | |
Re: Vent door seal
#22 |
Re: Vent door seal
Thank you. I'm in the que to get the damage fixed, however I may have a longer wait now that it has snowed here in raintown.
#23 |
Re: Vent door seal
60-66 seals have the middle cut out, 67-72 seals are sold full piece it seems, and the material is just like a foam, not even rubber. I think I have a 67-72 vent door can use as a pattern, also, I need better weather so I can pull truck out to get to it.
#24 |
Re: Vent door seal
innertube will last linger and probably seal just as well.
| Bookmarks |
