Old 04-05-2018, 02:18 PM   #1
Tiger Joe
stock 454 oil capacity
what is the stock oil capacity for the 454s from 73-87?
we swapped a 454 on our 79 C30. We have an original owners manual for a 79, says 6 qts. the engine we swapped in is supposedly out of a 76 pickup originally, was mostly irrelevant because we rebuilt it all, BUT we did use the oil pan on it. had no dipstick so I bought a replacement dipstick for a 79 454.
engine is exactly on full with only 5 quarts.
just want to figure out if I had the wrong oil pan, maybe the wrong dipstick, or if it really is supposed to only be 5 quarts
Tiger Joe is offline   Reply With Quote
Old 04-06-2018, 02:55 PM   #2
MJN
MJN's Avatar
Re: stock 454 oil capacity
Here is a link to a 1977 GM service manual. http://www.73-87chevytrucks.com/tech...ice_Manual.pdf
Bottom of page 0B-2, crankcase capacity without filter is 4 qts. The filter holds another quart so 5 quarts total assuming all stock parts were used. The 1979 GM service manual states 6 qts without filter change and 7 qts with filter change on page 0B-17.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 04-06-2018, 03:40 PM   #3
DieselSJ
Dipsticks and tubes should be matched for the year as there were some different lengths.
I don't know what the manual says, but my '87 takes 6 quarts when I change the oil and filter.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 04-06-2018, 07:39 PM   #4
100%Chevy
It all depends on the oil pan used and the size filter used.
I had a 427 TD that had a 10 quart pan and 2 quart filter.Came from a big tandem axle truck with a fifth wheel.
My 65 Impala with a 454 actually holds a little less than 5 quarts.
And,then there's add on oil coolers too.
If you have the original pan on the engine,look up the numbers on the engine and see what it calls for.
Mike.
100%Chevy is offline   Reply With Quote
Old 04-06-2018, 08:54 PM   #5
Tiger Joe
Interesting.
So they must have changed pans between 76 and 79 to allow for extra capacity.
And the 79 owners manual says 6 with filter not 7.
Old 04-08-2018, 07:20 PM   #6
tucsonjwt
My 83 C20 454 takes 7 qts. It is a camper special - deep oil pan, factory oil cooler, 1 qt. long oil filter. Surprisingly, it has never burned oil, but I drive it only in the city. I think if I hammered it on the freeway it would start to drink some oil.
tucsonjwt is offline   Reply With Quote
Old 04-09-2018, 08:31 PM   #7
Tom
driving is in my blood
Tom's Avatar
5qts......amazing. A 4cyl mercedes will take 8-9.
Old 04-13-2018, 08:58 PM   #8
LT7A
I have this exact same dilemma. My 454 was swapped in in lieu of a 6.2 diesel before I got the truck, and I don't know when it's from. Maybe you and I can post pictures of our oil pans and if anybody else that has a factory setup and knows their capacity is willing to post a picture, we can get closer by comparing oil pans. My dipstick shows full at 5 quarts, but my truck is a Camper Special and I would like to change the pan out to bigger capacity. But there's always a chance that I've just got the wrong dipstick.
