Old 04-05-2018, 03:51 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Hood Latch Seal
What is the consensus on which way does the lip of the hood latch seal go? Up or down?
Old 04-06-2018, 02:50 PM   #2
The Rocknrod
Moderator
Re: Hood Latch Seal
I bet it's the 2nd picture, what do you think?
Old 04-06-2018, 04:02 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
Re: Hood Latch Seal
This is how I have mine...just like your first pic.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-06-2018, 04:08 PM   #4
The Rocknrod
Moderator
Re: Hood Latch Seal
Okay thanks looks great.
Old 09-05-2020, 06:07 PM   #5
roll_the_dice
roll_the_dice's Avatar
Re: Hood Latch Seal
Good info...I had this seal with no idea where it went! LOL :-)
Now the question is how do the clips stay in place? Do the tabs get bent over or something else? If yes, what did you do to bend them over? Thanks
roll_the_dice is offline   Reply With Quote
Old 09-05-2020, 07:25 PM   #6
The Rocknrod
Moderator
Re: Hood Latch Seal
Squeeze the center, the tabs in the hole will expand outward.
Old 09-05-2020, 09:18 PM   #7
roll_the_dice
Re: Hood Latch Seal
Thanks Master Chief!
Old 10-18-2020, 06:40 AM   #8
G8rN@te61
Re: Hood Latch Seal
ok so my original seals on my '61 were stapled to the metal lip of the hood. I assume yours had square holes in it to push the tabs into place? Wonder how to make it work....
-Nate
G8rN@te61 is offline   Reply With Quote
Old 10-18-2020, 09:44 AM   #9
LT1 Burb
LT1 Burb's Avatar
Re: Hood Latch Seal
Funny thing with those, for ever I couldn't figure out why the paint on my radiator shields kept getting screwed up, then I realized it was that rubber that was doing it.
LT1 Burb is offline   Reply With Quote
