Old 04-05-2018, 09:33 PM   #1
Gunnin4ya
Dbw harness 2 wire plug
I bought a harness for my Gen 3 5.3. It is a stand alone harness and the builder said the dbw needs to be out of a 01-02 tahoe or yukon. I can not find one anywhere. Is he mistaken or do I just need to try and figure something else out? It is a 2 wire plug that is throwing me off.
Gunnin4ya is offline   Reply With Quote
Old 04-05-2018, 09:47 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Dbw harness 2 wire plug
There are some 01-02 trucks that got DBW, but usually it was the Escalade/Denali and top option trucks. Which PCM does it have?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-05-2018, 09:54 PM   #3
Gunnin4ya
It has the red and blue connectors on it. All I know is that it is flashed with a basic tune so I can start it once it is together.
Old 04-05-2018, 10:41 PM   #4
ls1nova71
ls1nova71's Avatar
So what exactly are you needing? All of it, throttle body, TAC module, pedal and the harness between the two? I had some extras but may have sold them, would have to check.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-06-2018, 09:33 AM   #5
Gunnin4ya
I will need all of it.
Old 04-06-2018, 09:33 AM   #6
Gunnin4ya
SO, there is a 2 wire plug for it?
Old 04-06-2018, 10:21 AM   #7
truckdude239
truckdude239's Avatar
From what ive read dbw wasnt a normall standard option till around 03 my 02 suburban is dbc as is my 01 tahoe
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-06-2018, 10:42 AM   #8
Gunnin4ya
Sounding more like I might be ordering another harness.
Old 04-06-2018, 11:24 AM   #9
ls1nova71
ls1nova71's Avatar
I haven't been able to check what all I have left, but for reference, this is what the throttle body looks like. What year is the engine you have? Because there are differences in the intake that make swapping the '03 TB not a straight forward deal. Also, if you get a newer harness to go with the '03-07 DBW stuff, you will need a newer PCM as well. Or, you could go with a cable throttle body with a different harness, or mod the one you have, and your PCM could be tuned to DBC.
Old 04-06-2018, 11:57 AM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Do you know what year the motor is from? Does it have a TB on it right now for reference?
Old 04-06-2018, 11:58 AM   #11
Gunnin4ya
It was a used motor and has the truck intake without the throttle body. Figured I would have to get it all to match so I wasn't to worried about it. I should have read up more. Turning into a pain. I appreciate all the info.
Old 04-06-2018, 12:09 PM   #12
ls1nova71
ls1nova71's Avatar
Does the intake have the PCV tube on it right behind the throttle body? If it does, then it's an '03 -'07, but if it does not, then it's a '99-'02. The older '99-'02 throttle bodies have this tube on them, so you cant put the older throttle body on the newer intake because they hit each other. If you go the other way, and have the older intake that has the tube on the TB, and you put on a newer TB, then you wont have a PCV tube at all... So, post up a pic of what you have so we know what you're working with.
Old 04-06-2018, 02:04 PM   #13
Gunnin4ya
Here is a picture of the intake. All I had on my phone. I can grab better ones when I get to the house.
Old 04-06-2018, 06:02 PM   #14
Gunnin4ya
Here are some better shots.
Old 04-06-2018, 10:57 PM   #15
ls1nova71
ls1nova71's Avatar
Thats a 99-00 intake, so you will need the older throttle body. Is there any reason you want the engine to be DBW? Seems easier to just find a DBC throttle body and rework the harness and PCM. I looked in my stash, and all I have is the newer stuff, but I see the older stuff at the Pick n Pull pretty regularly.
Old 04-06-2018, 11:32 PM   #16
Gunnin4ya
Just because I thought it would look cleaner and everything was programmed for it. I really appreciate all the help on this. I will keep looking for a dbw until it is ready to go in. If I can't find one by then I will start cutting the firewall and doing dbc.
Old 04-06-2018, 11:44 PM   #17
mongocanfly
Post Whore
mongocanfly's Avatar
not sure what yr truck your working on but I switched my 2002 6.0 from dbw to dbc...on my 81 I used the existing throttle cable firewall hole to run the cable thru..no need to cut firewall..its hidden under the engine cover and you cant see it...
I think ive still got that dbw throttle..its off a 2002 6.0.....but I don't know if its the one you need...ls1nova will know for sure
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-06-2018, 11:51 PM   #18
Gunnin4ya
65 C10 is what I am putting it in. Pulling out the 350 and putting this 5.3 in it. Just trying to get all the parts I need for it before I pull it out.
Old 04-07-2018, 12:02 AM   #19
Wildkarde
You need a wiring harness, tac module, TB, and pedal assembly from a 2002 or older DBW truck/suv. Preferably all from the same vehicle, and if you can get the computer with it all the better. Basically if it has red/blue instead of green/blue and isn't from a car it should work for you. There weren't a whole lot of DBW trucks in those years it was mostly SUVs.
Wildkarde is offline   Reply With Quote
Old 04-07-2018, 12:24 AM   #20
mongocanfly
Post Whore
sweet truck gunnin......
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-07-2018, 09:21 AM   #21
ls1nova71
ls1nova71's Avatar
If your throttle body is from a 2002 it should be what he's looking for. Does it look like the pic I posted? Also the TAC module will be the all plastic one, not the aluminum base type.
Old 04-07-2018, 11:28 AM   #22
Gunnin4ya
If you want to sell it WildKarde let me know. If it is the plastic one. Thanks Mongo, still changing stuff on it. Going to have to redo the suspension on it. Not happy with how it handles. I know it won't be a Bette but don't want a bus either. Lol. Nova I am going to owe you a beer with all the help you are giving me.
Old 04-07-2018, 05:19 PM   #23
Gunnin4ya
Ls1Nova, was checking out your builds. That is some amazing work you have done. Beautiful trucks, gave me lots of ideas for doing this build.
Old 04-08-2018, 09:08 PM   #24
mongocanfly
Post Whore
here's the throttle I have...it looks like ls1novas pic above....it even has the original "patina"...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-08-2018, 09:14 PM   #25
Gunnin4ya
Woohoo, that would be one step closer.
