Old 04-06-2018, 05:29 PM   #1
77CaliC10
1/8" Spacer or New Wheels?
Hey everyone,
I ran into an issue during my build and figured that this would be the best place for solid guidance... I have a 1977 C10 with a 4/6 McGaughys drop. The problem I am having is the new wheels (US Mag U101 slots in 15x8, with 4" BS) are hitting the spindle at the tie rod connection. The wheel is just barely unable to fully seat against the rotor (3/16" washers correct the issue). I am stuck, wheel shop told me they cant get the wheel with a 3.75" BS, I'm concerned the wheel will hit the tie rod if I grid the nub that is making contact now, and I have heard negative things about running spacers (even at only an 1/8")... Is it time to reconsider my wheels? I bought these because it seems that most people are running this size/BS combination... Maybe its time to think bigger... Thanks in advance!
77CaliC10 is offline   Reply With Quote
Old 04-06-2018, 08:30 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 1/8" Spacer or New Wheels?
funny you post this today...I just got a set of us mag 8x16 wheels with 5.25 bs ,and they almost hit the tie-rod end as well...just like yours...it is very close but it clears..if it becomes a problem im going with a 1/8 spacer...my wheels arnt hub centric so I don't think it will hurt a thing...lots of people run spacers with no issues..and a lot more than 1/8"
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-06-2018, 08:52 PM   #3
wilkin250r
wilkin250r's Avatar
If you go with spacers, just make sure you get enough engagement on those lugs. You're going to want about 7 full turns.
I'm not going to be a doomsday prophet. "If you only have 6 turns, you're going to die!!!" But every turn you're missing just increases your risk that much more.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 04-06-2018, 10:58 PM   #4
77CaliC10
Is it possible to get a hub-centric 1/8" spacer? I've found lots of larger (1-2.5") bolt on style hub-centric, but I'm assuming this will be more of a shim, but I would still like it to be hub-centric if possible. Maybe it doesn't matter when its that thin.
Old 04-06-2018, 11:28 PM   #5
mongocanfly
Post Whore
are the 101s h-c? if so how much contact does the wheel make to the hub center
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-06-2018, 11:46 PM   #6
Dads79GMC
Dads79GMC's Avatar
I have 7" Rally's up front, with 4" BS and they clear w/McGaughy's spindles. However, my 8" Rally's did not and they have 4.25" BS, thus the reason I had to switch to sevens. When getting the tires/wheels balanced, I had them use stick-on weight vs. the ones that attach to the edge of the rim.
I'm surprised the 4" BS are that close. I did attempt 1/4" spacers, but didn't go with it??
Thanks Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 04-07-2018, 01:18 AM   #7
77CaliC10
I haven't used a micrometer, but a rough tape measurement shows the wheel bore and hub to both be 3 inches, so I am assuming some contact. But, it raises a good point, I am not sure if those wheels were meant to be hub-centric. It does not state on their site, but as far as I am aware most aftermarket wheels are lug-centric. They do have a conical seat for the lug nuts. With the wheel sitting 2-3/16 off the face of the rotor, and I can get 6-3/4 full turns out of the stock stud/lug nut. I am sure a 1/4-1/2 (if not more) turn would happen upon torquing.
