04-06-2018, 08:27 PM | #1 |
Truck bed mat
Since no one make a mat for our trucks I looked around and found that they make a horse stall mat that is 4’x6’x3/4 or 5/8 thick. I went and picked up 2 mats spent about a hour and voila a bed mat that fits perfectly. The box is exactly 6’ wide( long box) and just cutout wheel wells. Mat cost me $80.
04-06-2018, 08:39 PM | #2 |
20' Daredevil (Ret)
Re: Truck bed mat
Those things are incredibly tough (and heavy!). I have had one in my truck bed for a few years and it's virtually like new. Didn't get two and line the entire bed floor, just one between the fenderwells and touching the front of the bed.
04-07-2018, 09:46 AM | #3 | |
Re: Truck bed mat
choctawchevyclassics |
04-07-2018, 01:19 PM | #4 |
Re: Truck bed mat
couple of pictures
04-07-2018, 05:39 PM | #5 |
20' Daredevil (Ret)
Re: Truck bed mat
That looks great! What did you use to cut them?
04-07-2018, 06:07 PM | #6 |
Re: Truck bed mat
I used a rechargeable circular saw for straight cuts and a large box cutter for the corners. The mat actually cuts pretty easy with the box cutter.
04-07-2018, 07:07 PM | #7 |
Re: Truck bed mat
The trick is to lube the box cutter with soap
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
04-07-2018, 07:54 PM | #8 |
20' Daredevil (Ret)
Re: Truck bed mat
Good to know, thanks for both replies.
04-08-2018, 02:20 AM | #9 |
Re: Truck bed mat
If you have a steel bed you'll want to avoid trapping moisture between the steel floor and the rubber mat. One 1/2'' or 3/8'' hole in each corner will do the trick. If there's a wood floor underneath, you can skip it.
Would one horse mat cover the back deck of a K/5?
04-08-2018, 09:08 AM | #10 |
Re: Truck bed mat
The bottom of the mats actually have hundreds of 1/4” dimples so air can get under. I will post a picture.
04-08-2018, 10:22 AM | #11 |
Re: Truck bed mat
Here are a couple of pictures of underside of mats
04-08-2018, 10:30 AM | #12 |
Re: Truck bed mat
Where did you buy those at ?
04-08-2018, 11:48 AM | #13 |
Re: Truck bed mat
I bought them at a farm store called North 40 also know as Big R. I am sure any farm,ranch supply store will have them
04-08-2018, 12:47 PM | #14 |
Re: Truck bed mat
Someone does make them. I posted this before in the 66 form. I will need to find it.
04-08-2018, 12:51 PM | #15 |
Re: Truck bed mat
The maker of the mats is. Red Barn
Red Barn Lite Stall Mats $42.99 +25 Write a review Red Barn Lite Stall Mats Select Quantity LOAD THE TRUCKCecelia North 40 Icon Truck |
04-08-2018, 01:05 PM | #16 |
Re: Truck bed mat
The local Tractor Supply has them for 39.99 I was looking at them last night. I have had a mat made from conveyor belting from a local manufacture, but it has seen it better days. I have been considering one for my step side.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
04-08-2018, 03:42 PM | #17 |
20' Daredevil (Ret)
Re: Truck bed mat
That's where I got mine, Tractor Supply Co.
04-09-2018, 01:45 PM | #18 |
Re: Truck bed mat
I have not bought one yet because it measures 5" short and I don't need a 5'7" left over piece if I buy 2.
