04-06-2018, 09:06 PM | #1 |
A Little Ball Joint help Please
I took the 71 in for alignment and was told the upper right ball joint was worn, so I bought a complete set of Moog upper and lowers. The joints popped out OK but I can't get the lower joint off of the A Arm. It looks like it should be simple. I looked at the new one and all there I see is a serrated collar that needs to be pushed out of the arm. I supported the A Arm with some wood and fit a piece of pipe over the joint so I could smack it out. Not happening! Any tricks to it or should I get a bigger hammer??
04-06-2018, 09:17 PM | #2 |
Re: A Little Ball Joint help Please
I recently replaced the balljoints on my truck with hand tools. There's a balljoint tool you can rent from most auto parts stores. I was able to press the old joints out with it, but could not get the new ones in. I ended up using the collar from the tool and hammering on that with a BFH to seat the new balljoint. After struggling with it while the arm was still connected to the truck, I found it was much easier to do after I pulled the arm off.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
04-06-2018, 09:31 PM | #3 | |
I heard Harbor freight had a lower ball joint press tool but I can't find the type I need on line. I wonder if anyone has a link or a picture of said tool? |
04-06-2018, 09:34 PM | #4 |
Who Changed This?
O'Reilly's has the press. Is that where you went to get it? The counterman at O'Reilly's told me that they didn't have the tool to remove the lower ball joints, so I ended up buying a cheap hydraulic press from Harbor Freight. Then I discovered that the tool actually did both.
04-06-2018, 09:37 PM | #5 | |
04-06-2018, 10:44 PM | #6 |
I recently decided I would buy a ball joint press instead of borrowing my friends. I discovered i could get one off eBay or amazon cheaper than harbor freight.
But yah...renting from the auto parts store is a good idea too... I recently used my 20 ton harbor freight press with a short length of 1 1/2 Inch pipe to press the lowers out. |
04-06-2018, 11:29 PM | #7 |
I tried to rent the proper tool, could not find it at the local parts places. Finally decided to let my mechanic friend handle it. He had the proper tool, so I helped and when it came time to the lowers we took em down to the local machine shop.
10 bucks a side popped out the old and in with the new. Even he told me with the tool they can be a total pita. |
