Old 11-10-2003, 12:37 AM   #1
71HUGGER396
Confirmed Truckaholic
71HUGGER396's Avatar
ram horn exhaust????
I was just wondering which style of ram horns fit our style two wheel drive trucks best. I'm tired of messing around with headers. How many styles are there?? I have a two wheel drive with a 350 engine. Thanks
71HUGGER396 is offline   Reply With Quote
Old 11-10-2003, 12:46 AM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
From the factory, every C10 i have seen has had 2" ramshorns that angle back towards the cab when they end.
You could dump the manifolds and get a set of headers
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 11-10-2003, 12:49 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You can pick up a set of brand new ram horn's from your local dealer. I think they were about 85 a piece last time I ordered a set..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-10-2003, 12:51 AM   #4
Dan72cst
Dan72cst's Avatar
2wd trucks came with the Ram Horns that angle back. 4wd trucks came with the ones that exit straight down.
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
Old 11-10-2003, 12:53 AM   #5
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
What kind of problems did you have. I got dyno-max ceramic coated headers on my 2wd with a 350. The exhaust pipes run up and over the crossmember. Works fine no problems yet.
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 11-10-2003, 12:54 AM   #6
Southpa
Southpa's Avatar
I was curious about how much the local GM dealer was selling them for. Got quoted $437 (Cdn) EACH!
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 11-10-2003, 01:01 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Two options for new.
1) GM Performance Parts sells the vette ramshorns 2 1/2 inch for about 80 each.
2) the truck ones are WAY higher. My neighbor is a GM parts guy. His cost (what the dealer actually pays) is right at 150 each for the truck ramshorn.
Old 11-10-2003, 02:25 AM   #8
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
I had to replace a cracked one. Had to pay about $90 or so for one, but it had theaded air holes for a smog pump. Had to buy some stoopid looking brass plugs for it.
Cat Fuzz is offline   Reply With Quote
Old 11-10-2003, 02:40 AM   #9
greenhorn male
greenhorn male's Avatar
Why are the 2wd ramhorns curved and would the straight ramhorns work with 2wd's?
greenhorn male is offline   Reply With Quote
Old 11-10-2003, 02:45 AM   #10
cheyenne10
cheyenne10's Avatar
2.5 vette ramhorns
I have read posts before about these units. They are straight dump and work on 4x4's. Anyone using on 2 wheel drive trucks? Exactly what cut needs to be made on drivers manifold to cut off Alt. boss? Are there any other interference problems with stock bracketry or direct bolton in 4x4? Who has part numbers and vendor info? Is there a left and right one or are they the same?
Hope I'm not pirating this post but adding to it.
Bob
cheyenne10 is offline   Reply With Quote
Old 11-10-2003, 02:59 AM   #11
A.P.
Black 72 Chevy
A.P.'s Avatar
I bought a used one for $10, at an auto wreck yard.
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 11-10-2003, 09:49 AM   #12
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I made the cuts to the vette ones. I'll take some pics and post when I get home (4pm),
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-10-2003, 10:39 AM   #13
71HUGGER396
The only problem with headers are the with gaskets that blow out. I just picked up a truck and there is no motor or tranny and I plan on using it as my daily driver. I want to put it on the road by springtime and not have to mess with it after that . My other truck has a built 454 and thats my toy. This one will be my transportation. I'm ordering a plain old stock crate goodwrench 350 fot it. Do headers really make much difference on a stock engine?
Old 11-10-2003, 11:24 AM   #14
gr8scott51
gr8scott51's Avatar
I'm straight
...not that I have to affirm my.... oh never mind.
I have the ramhorns that dump straight down on my 2wd 68. I got them cermachromed (ceramic coating that looks almost like chrome but doesn't turn blue).
scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 11-10-2003, 12:13 PM   #15
Hugger
Hugger's Avatar
A new one in Wichita was $169. I found a used one in great condition for $50 and then had to have the studs chaged out $35.
So $85 for a new one would be a great deal.
72 LWB - Hugger Orange
350/350 3.73
Next; 335hp GM Crate
Hugger is offline   Reply With Quote
Old 11-10-2003, 12:18 PM   #16
Tx Firefighter
I've got a brand new GM NOS right side manifold I tried to sell on the parts board. The deaership my neighbor works at pays about 150 their cost for a manifold. I tried to sell it on the board for 100 with no takers. Still has the tags on it. I guess there is still a ready enough supply of used ones.
Old 11-10-2003, 04:13 PM   #17
71gmcfanatic
Ive got some 2wd ramhorns for sale right now, they would fit your truck. I just pulled them from my daily driver, worked perfect, no leaks.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2442067957
1971 gmc 3/4 ton, 350, t350
71gmcfanatic is offline   Reply With Quote
Old 11-23-2003, 12:36 AM   #18
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
I got a set of the ramhorns that go straight down all the studs are there. I got headers and took em off. I'm in eastern NC couple hours southeast of raleigh if you want anymore info hit me up. They came off a 71 with a 350 and automatic tranny on the column. I'd be willing to part with em for $75 but very willing to negotiate
WRMZ71 is offline   Reply With Quote
Old 11-23-2003, 02:30 AM   #19
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
I've got the straight ramshorns on my '67 GMC 2wd and have no problems.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 11-23-2003, 12:15 PM   #20
Mike C
Mike C's Avatar
Here are some observations of mine: 67 and some 68 trucks had straight dump manifolds. 69-72 had angled manifolds. The 4x4 all had straight dumps. Someone building a truck can use the mounts in the 6 cylinder location. This gains quite a bit of clearance to the steering, frame, and crossmember allowing straight dump 'vette manifolds to be used easeir.
Another solution to leaky headers, EXPENSIVE gaskets. Use the Mr.G ultraseal or FelPro gaskets that have screen wire sandwiched in between the two halfs. COmbine those with header bolts using lock washers and you should get 7-10 years from a set of gaskets. My last set of gaskets lasted longer than the steel flange on the collector.
I replaced my Heddmans with 'vette manifolds and could not be happier.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-23-2003, 12:20 PM   #21
dubie
dubie's Avatar
I put the center straight dump ones from a 4x4 on mine just to make sure my exhaust will clear my clutch linkages.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
