04-07-2018, 08:21 PM | #1 |
66 C10 BBC Exhaust System Help
Looking for an exhaust system kit with the following setup:
1. Installed 396 BBC with Sanderson Headers C6SEC. 2. Installed CPP Trailing Arm Crossmember to allow piping to run thru. Was hoping for a dual exhaust system that i can do myself. Any suggestions would be appreciated. |
04-08-2018, 07:33 PM | #2 | |
Re: 66 C10 BBC Exhaust System Help
04-08-2018, 09:39 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Summit racing! DIY exhaust
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-09-2018, 12:04 AM | #4 |
60-66 Nut
I don't think you will find what you are looking for without doing a bit of cutting and welding to make it fit. I believe Magnaflow makes a stainless exhaust system for the '63-'72 trucks but I don't know how it is routed.
I just looked and see that this kit is now available again. It was unavailable for a long time. This is a pretty darn good deal for a mild steel exhaust system. http://www.jegs.com/i/Dynomax/289/89027/10002/-1
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 04-09-2018 at 12:10 AM. |
04-09-2018, 01:45 AM | #5 |
I took mine to a shop and they did a 2 1/2" dual exhaust for $300. Maybe make some calls and see what's in your area.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
04-10-2018, 12:13 AM | #6 |
60-66 Nut
That's a heck of a deal! The last time I had a 2-1/2" exhaust installed it was $250 and that was over 25 years ago.
04-10-2018, 01:46 PM | #7 | |
built our own using the builders kit from Flowmaster |
04-10-2018, 10:22 PM | #8 | |
11-11-2021, 08:53 AM | #9 |
Robert , how did you handle the H pipe crossover?? that is where i need to start. Last edited by Afirehawk1; 11-11-2021 at 08:54 AM. Reason: typo |
12-20-2021, 08:32 PM | #10 | |
What adapter or flange is being used around the H pipe Found the Flowmaster DIY kit But i need to order the flanges Thanks |
12-21-2021, 10:15 PM | #11 |
Get on ebay and get some v-band clamps for you size tubing
12-21-2021, 10:23 PM | #12 |
