04-07-2018, 08:31 PM | #1 |
Steering Column Shaft Too Long
Im Using A Tilt Column Out Of A Newer Van for my 70 chev Truck. The Steering Column Shaft Is About 3 inches Longer Than The Stock One.. can I Drill Out The plastic Inserts, Slide Out The double D shaft And Cut It? Thanks
Posted via Mobile Device |
04-07-2018, 11:56 PM | #2 |
Re: Steering Column Shaft Too Long
just drill out the plastic tabs and drive the shaft down, no need to cut.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
04-08-2018, 12:11 AM | #3 |
The Older Generation
Here are a couple of threads on the subject. http://67-72chevytrucks.com/vboard/s...d.php?t=133937 http://67-72chevytrucks.com/vboard/s...d.php?t=210459 LockDoc
04-08-2018, 02:43 AM | #4 |
Thanks Guys. Thats Awesome. Just Curious,The old column had a Round washer and spring. Does anything take Their place or do i not use them?
04-08-2018, 10:01 AM | #5 | |
Those two pieces held the lower bearing in place on your other column. You don't need them on this one.... LockDoc
