Old 04-08-2018, 08:26 AM   #1
jmcap
My '65 patina rat
I tired of my Trailer Queen Mopars. Sold them to start a new project. As I've aged I realize what I really like. Found this beauty with a 350 and 700r4 Tranny, Disc brake conversion, etc. Just finished installing rear lowering coil springs.
jmcap is offline   Reply With Quote
Old 04-08-2018, 09:34 AM   #2
Rusty63
Rusty63's Avatar
Re: My '65 patina rat
nice stance!
Rusty63 is offline   Reply With Quote
Old 04-08-2018, 02:38 PM   #3
pdxhall
pdxhall's Avatar
Welcome to the forum. That looks like a great truck. Good luck.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 04-08-2018, 02:41 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Are you going to make it a shiny trailer queen?
66 C20 Service Truck:
Old 04-08-2018, 08:25 PM   #5
jmcap
Talking Re: My '65 patina rat
Thanks all for your kind words. Paint ?? Nah. Done with polishing. Besides, it might throw things out of balance.
Old 04-09-2018, 12:37 AM   #6
Captainfab
60-66 Nut
What other plans do you have for your truck?
Old 04-09-2018, 07:40 AM   #7
Nice looking stepper!
Old 04-09-2018, 06:28 PM   #8
jmcap
The truck had no bed floor............ So I bought a 4X8 oak veneered plywood and will cut to fit and hinge at the cab end. My Dad had some extruded aluminum runners he intended to use on his smoothie running boards in his supply of parts. The final look will mimic the kits that sell for too much than what I want to spend. I'll provide pics when completed. Remember. It's a rat rod !!
Old 04-12-2018, 03:31 PM   #9
aggie91
I'm just glad to be here!
aggie91's Avatar
Can't wait to see how your plywood floor turns out. I have been thinking of something that sounds similar to what you described...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-13-2018, 05:25 PM   #10
jmcap
I'll have to wait on the truck bed until I install the external gas tank I ordered and see where the fill tube will be. At this point I have a lot of parts to be installed but need to be smart with the order of installment. I think the saying is "Don't put the cart before the horse.?
Old 04-15-2018, 03:27 PM   #11
rusty76
rusty76's Avatar
I’ll be watching. Welcome to the forum.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-16-2018, 08:01 AM   #12
jmcap
As we all know, buying someone else's project comes with pros and cons. After examination, I found that along with the dropped spindles from Classic Performance and required disc brake conversion ( a positive ) , the wrong springs and shocks were used to further slam it to the point that the truck was resting on the bump stops!! ( a definite con ). After speaking to the techs at Classic Performance, I'm following their recommendations to provide the stance and safety that is required and purchased springs and shocks that in combination with the spindles will give the truck an overall drop of 4" at the front. As a result, the original post with the picture I added showing the result of me further lowering the rear was all for nothing and will be returned to the slightly taller stance to avoid any rake.
So, while waiting for parts to be delivered, yesterday my father, brother-in-law, and I prepared the truck for surgery. After swapping out the rear springs... an easy fix, we jacked up the front and secured with jack stands. Coil springs and shocks were removed waiting for the 'transplants' to arrive. I'll let you know how the patient makes out.
Old 04-16-2018, 04:40 PM   #13
okndn
Very good start
okndn is offline   Reply With Quote
Old 04-17-2018, 06:51 PM   #14
rusty76
rusty76's Avatar
I’ll be watching.
My build thread
Crossmembers CC
Old 04-17-2018, 07:11 PM   #15
jmcap
Glad to know your with me Rusty 76.
Failed to mention that when we tore the suspension apart this past weekend, we as well pulled the passenger side rear axle to get ready to replace the oil seal.
Today, after work I replaced the seal, installed the axle, spider gears, and c clamp, buttoned it up, added oil and the rear is done!!
On my doorstep was a new exterior gas tank. Can't wait to get the gas out from inside the cabin!
