Roadtrip!
![]() Join Date: Feb 2003
speedwarning ?
Does anyone know exactly where the knob to set your speedwarning comes through? I have seen them come through the plastic bezel, and through the metal dash itself. If anyone can verify location, can you give me exact measurements? Any help appreciated! Eric
I put mine here.
Only pic I have of it right now. I used an original speedwarning bezel cluster to locate the position.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
![]() Join Date: Mar 2000
I have over a dozen original speedwarning dashes and all have the speedwarning knob located exactly where Rod's photo shows it. It doesn't matter if the dash bezel is gauge or non-gauge either its always in this location.
GMCPaul Thought I better come back and post due to the # of emails we've received regarding buying our speedwarnings and or speedwarning parts, the fact is None of our speedwarnings or speedwarning related parts are for sale, they will either be used in the original truck they came out of ( We have 5 original trucks that came with them, or will go in one of our other 13 others trucks that did not originally come with one. GMCPaul Last edited by GMCPaul; 11-10-2003 at 02:44 PM. |
Roadtrip!
So it looks like i center it off the lower corner of of where it reads lights, to the nearest point of speedo? The 67 i parted had it listed as an option (i believe) and the knob came through the metal part of the dash about centered with the speedo. Could this be correct also? Thanks for the pic and knowledge! Eric
another pic
Roadtrip!
Now i see the "bigger" picture, thanks, Eric
