Old 04-08-2018, 09:13 PM   #1
landarts
landarts
Window felts and wind wing rubber...oh my!
Is there a better rubber product out there than Precision? I rebuilt the wind wing vents over a year ago and installed into the doors. At the time I thought maybe the rubber would lay down after a little time. It has been in the garage the entire time since the build is not complete. I just did the widow felts today and I am really disappointed with the quality of how these lay down also. Is there something I am missing here, or is the expect quality of rubber products available.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 04-08-2018, 09:29 PM   #2
BlueBullet
BlueBullet's Avatar
Re: Window felts and wind wing rubber...oh my!
The vent window rubber should be tucked into door and on the window wipers I had to trim them a bit to fit right.
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 04-08-2018, 09:29 PM   #3
panhead59
Try calling them and sending them pics. I'm ordering from them soon but will return em if they look like that!!!! Good luck. It will be interesting to see if they stand behind their product. keep us posted pls.
panhead59 is offline   Reply With Quote
Old 04-08-2018, 09:35 PM   #4
BlueBullet
BlueBullet's Avatar
Here's a picture of ones I just got done with Precision seals and wippers
1967 Pontiac GTO
Old 04-08-2018, 10:27 PM   #5
HO455
Post Whore
HO455's Avatar
I made the same mistake. That's the problem with taking it apart and putting it back together months later. (That's my excuse anyway!) That and most other vehicles the seal goes over the steel so you assume it should here too.j
RIP Bob Parks.
Old 04-09-2018, 09:03 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
The guys are correct, The bottom of the vent window gasket/seal should be inside the door and you have to trim the window seals and wipers to fit.
LockDoc
Leon
Old 04-09-2018, 10:29 AM   #7
landarts
landarts
Thanks for the advice, I will get the rubber tucked in on the vent wing and remove and trim the others. Still does seem that the window rubber on the outside of the door will not ride up on the window like it should........thanks!
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 04-09-2018, 11:22 AM   #8
LockDoc
LockDoc's Avatar
Most of the rubber on the outer seals are too short and don't reach the glass. The problem could also be that the metal strap between the inner and outer door panels is broken and the door is spread apart. Here is a picture of the strap and where mine was cracked. If there is a gap between your vent window rubber and the outside of the door this may be the problem. This happens to be a '72 door so it shows the clip for the door screw also.
LockDoc
Leon
Old 04-09-2018, 12:04 PM   #9
landarts
landarts
Here is a quick drawing of what I feel that the outside wiper is not doing. I thought that it was supposed to ride up on the window so that when it rains or snows it will shed the water away from going down inside the door. In some places mine does that a little but in some it is actually curved down. So it is not functional and it just plain looks like a bad fit.
The drawing is what I am trying to explain.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 04-09-2018, 09:12 PM   #10
HO455
Post Whore
HO455's Avatar
I don't believe that GM designed them to keep water out. They are meant to keep debris from getting inside the door and plugging the drain holes and to keep the window frame from scratching the glass. There were no factory electrical components inside these doors so there was no requirement to keep things dry. The same basic style of felts and wipers are on my 51 GMC.
RIP Bob Parks.
Old 04-09-2018, 09:33 PM   #11
Elliot949
Elliot949's Avatar
Thank You for doing this post... I have the same issue on my truck... with the wing vents... so now I have to take my door apart to fix it...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 04-09-2018, 09:52 PM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
Precision has always been a top name in window gaskets
The last wing vents and window rubber products I used came from Steele Rubber Products.
https://www.steelerubber.com
High quality parts.
Keith
Convert to disc brakes.
Old 04-10-2018, 10:45 AM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have had nothing but fantastic results witn Precision's products when installed correctly. I didn't trim the window sweep on mine and they were a bear to make fit next to the vent window post. Then I looked at the factory ones I pulled out of there, I noticed that even those were trimmed to fit. Once trimmed them they fit perfectly.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-10-2018, 11:11 AM   #14
choctawchevyclassics
choctawchevyclassics's Avatar
Following, because I am getting ready to do the same job on my 67. Thanks for all of the info...
choctawchevyclassics is offline   Reply With Quote
Old 04-10-2018, 11:39 AM   #15
Lanman1972
Lanman1972's Avatar
I finished my truck 3 years ago and never liked the way the wing window rubber looked. Now I know why, I didn't install it correctly. Once my truck comes out of storage that will be one of the first things I fix, tucking the seal inside the door. Thanks
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
