Old 04-09-2018, 11:08 AM   #1
Curt - TN
1950 - Installing Inner Cab Weatherstrip???
What is the secret to installing the inside cab weatherstrip? I have tried sliding it on with limited success but looking for a process or install sequence recommendation.
Thanks,
Curt
Brentwood TN
1950 Chevy 5 Window 3100 - Check out my Build Thread: http://67-72chevytrucks.com/vboard/showthread.php?t=724260
1957 GMC 100
Curt - TN is offline   Reply With Quote
Old 04-09-2018, 12:35 PM   #2
Erics51chevy
Re: 1950 - Installing Inner Cab Weatherstrip???
Weather stripping that holds the headliner?
Erics51chevy is offline   Reply With Quote
Old 04-09-2018, 01:08 PM   #3
Curt - TN
There is a channel that goes all the way around the inside of the cab, I believe it is call cab weatherstrip. If you look at the blue truck in the upper left it has a door strip and a cab strip. The channel in the cab that holds it is broken into 3 parts.
I am not clear if it should be one continuous strip or if the rubber is broken into 3 parts.
Curt
Brentwood TN
1957 GMC 100
Old 04-09-2018, 02:47 PM   #4
crossfire84
crossfire84's Avatar
Go to my thread post #162 took me about 20minutes to do both doors.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 04-09-2018, 03:17 PM   #5
Curt - TN
Thanks for the tip, I will track down some of that stuff. Does it wash off or is it just a mess
Question, there are 3 separate channels, where did you start or is there a sequence. I started at the top front and got it down to the floor on the front side but when I tried to go the other direction I got hung up half way down.
I also thought it was called wind lace but could not find it labeled that way on the parts sites
Curt
Brentwood TN
1957 GMC 100
Old 04-09-2018, 03:29 PM   #6
crossfire84
It washes off with a damp rag. Got mine at Menards.
I started at the open corner and slid it down to floor first then pulled it up and around. Make sure to really fill the channels and the rubber groves liberally.
It is called wind lace.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 04-09-2018, 03:31 PM   #7
jweb
jweb's Avatar
First, inspect the windlace channel to make sure it has an even gap all the way around. I have seen several that were crushed, making it impossible to get the windlace in.
I started at the bottom rear and used one of these tools to press it into the channel: https://www.dkhardware.com/chisel-en...uct-13834.html
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 04-10-2018, 03:12 PM   #8
lower50's
lower50's's Avatar
I made up this little tool to make sure the channel is even all the way around, then used wd40 and started in the back upper corner. Worked very well.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 04-11-2018, 10:23 PM   #9
Curt - TN
Thanks for the tip, I picked up some of the Ideal Goop at Lowes then I made a mess gooping it on and I got one side completed in about 20 mins. It went much better than my last many attempts!
I also found a few crushed points in the channel that I had to open up. Another night and I will get to the other side done.
Curt
Brentwood TN
1957 GMC 100
Old 04-11-2018, 10:23 PM   #10
Curt - TN
Attachment 1773790
That is a good idea, thanks!
Curt
Brentwood TN
1957 GMC 100
