Old 04-09-2018, 11:26 AM   #1
leisure67
leisure67's Avatar
2wd vs. 4wd frame
Are the frames the same on a '76 swb 2wd and 4wd?
1970 K10
1970 C30
1973 C30
1980 K20
leisure67 is offline   Reply With Quote
Old 04-09-2018, 04:25 PM   #2
sweetk30
sweetk30's Avatar
Re: 2wd vs. 4wd frame
for the most part yes .
the front end stamping for the brake hoses and crossmember are a hair different .
also the brackets will need to be added to the 2wd frame to make it 4wd . and the front spring hangers for the rear springs need swapped or add a 3" block to bring the rear up to the 4x4 height .
places like www.diy4x.com can sell you a kit to make it swap over to 4wd . www.offroaddesign.com has some parts also like a engine cross member for the 4wd .
but if you have a frame you need and the body off the other its just a swap over for the most part . I am currently doing a c-10 to k30 body swap . need the 4wd more than 2wd .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 04-09-2018, 07:19 PM   #3
leisure67
leisure67's Avatar
Thanks. I am trying to use a 4wd frame for a 2wd.
1970 K10
1970 C30
1973 C30
1980 K20
Old 04-09-2018, 08:55 PM   #4
sweetk30
sweetk30's Avatar
then reverse the info i gave you .
heck if you were closer i would prob give you a good mid 80's long bed frame 2wd and you just chop it down .
you will have some holes to drill .
i am surprised you cant find a decent 2wd frame already .
Old 04-09-2018, 09:11 PM   #5
cruizin01
Check out my build and there is some info in there. Let me know if you have specific questions.
'78 C10 Build
cruizin01 is offline   Reply With Quote
