68 big block truck question
Hey guys am looking to maybe buy a 68 2wd 68 c10 short box cst truck and was wondering if there is a way to tell if it was an original big block truck if it doesn't have the spid plate on the glove box door ? Any help would be great
![]() Join Date: Mar 2003
Re: 68 big block truck question
Location of engine, mounts, radiator size, shroud, overall appearance. Brackets and accessories. Possible heat shield on right hand side, dual exhaust brackets on frame.
Active Member
![]() Join Date: Oct 2002
Im pretty sure that the Big Block pass side heat shield started with the 69 model, so it shouldn't have one.
Couple other things to look for are, high hump floor, and power steering res should be mounted to the drivers side fender. But a good way to tell is as kwmech said, check the frame, Big block trucks have factory dual exhaust, so check for factory hangers on the pass side of the truck. |
Ok would anyone happen to have a picture of the hangers by chance
Who Changed This?
![]() Join Date: Jan 2013
If your truck came factory as a big block, I'd be quite surprised if someone put single exhaust on it. The parts books wouldn't show a single exhaust system, if they all came with dual exhaust.
With 68's being 50 years old, it may be difficult to tell some of these things.
Mine is a stock example, although was not in great condition when I got it, not much better now (I am reviving it slowly...LOL) If the factory hangers are still on the pickup, the pass side would be the same as the driver side. Mine obviously had several sets of exhaust systems on it, in it's life time. Not sure the all the original hanger stuff is still on it. I will check one of these days to be sure.My pickup came with a muffler shop single exhaust on it, or at least what was left of it... I'm not exactly sure about the heat shield on the ex manifold. I still have my manifolds, somewhere in the garage....seems like some type of sheet metal was riveted to one of them. The high hump would be a for sure thing for a big block, but I wonder if all big blocks had power steering? That may not factor into all of them..Mine does have power steering, with remote reservoir. The motor mounts AND the motor mount stands ARE different. It may be nearly impossible to tell the difference from a small block motor mount stand without having one in your have to compare. The big block mounts have a large rubber cushion on the under side of the motor mount stand. Some vendors sell these mounts, I believe Brothers does, you may look on their sight to see what the mounts look like, for comparison. The small block mounts only have the bolt and washer on the under side of the mount stand, no rubber cushion, The top sides of the big block and small block mounts look similar....FWIW... |
Roadtrip!
![]() Join Date: Feb 2003
If it has power steering, the remote can should have an extension holding it away from the drivers fender. Still bolted to the fender, but the can will be out about 5"
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#8 | |
No choke on my cluster. Last edited by 68Gold/white; 04-10-2018 at 11:11 AM. |
not sure if you can tell, the driver side is a little easier to see the framme is cut back by the upper control arm. see how the frame narrows down. this is a 68 factory 396 truck.
#10 | |
If the spid is missing on the door and you want an original big block I don't think you could ever really prove that it was a factory big block. Just saying if you paying for originality better make sure it has the original spid.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
#11 | |
The Older Generation
Here is a thread I posted with all of the different mounts/stands..... http://67-72chevytrucks.com/vboard/s...d.php?t=732393 LockDoc
![]() Join Date: Jan 2007
What the others said (except no heat shield in 68). Also it would have had a choke delete gauge cluster (no raised “choke” letters).
I’m in for some pictures!
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#13 |
Frame looks narrowed on both sides, where the motor mount stands bolt on???
#14 |
Leon's picture shows the rubber cushion (68-71 big block) that is on the under side of the mount. The steel sleeve goes through the frame stand and into the mount that bolts to the engine. I'm glad to see someone making these now, I believe it's Brothers...GM used to be only source, I'm sure that dried up years ago...
Thanks Leon! Hope spring finally comes to Iowa, soon!!! |
#15 | |
No problem. Spring is here for two or three days then back to winter.... ![]() LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-11-2018 at 04:35 PM. |
