Old 04-09-2018, 10:35 PM   #1
wsben03
Shock relocation
I just purchased a 71 c10 shortbed coil spring rear and I want to lower it 3-4” in the front and 5-6” in the back. I am thinking about the bell tech lowering kit with the street performance shocks. My question is I see a lot of other kits have shock relocation brackets but this one doesn’t does that make a difference? Do I need to relocate them and if I do can I get any relocation brackets and use th bell tech shocks or do I need different shocks? By the way the bell tech kit is a 3” drop spindle and 1” lowering spring in th front and 5” lowering springs in the rear. Part #709sp. Thanks for any help
wsben03 is offline   Reply With Quote
Old 04-10-2018, 06:36 AM   #2
PGSigns
PGSigns's Avatar
Re: Shock relocation
Couple of questions. What wheels are you planning to run? That kit has 3" spindles so your going to need 17" wheels. To me that is a base kit that you need to ad options to. You will want to ad the shock relocators and and a long adjustable track bar like the Early classics bar. I would also ad a 2 degree shim under the trailing arm mounts to correct the pinion angle. You will see them listed for the trucks on some sites.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-10-2018, 07:12 AM   #3
wsben03
Thanks jimmy I just picked up the truck it’s a 6cyl so I’m planning on doing a 350 swap so I’m trying to lower it somewhere in that range without spending too much money but at the same time I want to do it right do you have any better suggestions as far as a different kit or piercing one together myself? I like the spindle drop in the front for performance reasons.
Old 04-10-2018, 11:26 AM   #4
PGSigns
PGSigns's Avatar
I prefer a 2 1/2" spindle for wheel choice options I have thier springs and shocks and like them. I use the ECE super track bar and there shock brackets.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-10-2018, 12:59 PM   #5
wsben03
ok i think i might go with a 2 or 2.5" drop spindle so i can try to keep my 15" wheels for now. if i went with ece shock brackets i can just use that with the belltech shocks how do i measure the size or length that the shocks need to be?
Old 04-11-2018, 12:00 AM   #6
66 C10 383
Using a drop spindle in the front doesn't need a shorter spring because the mounting points don't move. The only need for a shorter shock comes in with the lowering spring. Same situation with a drop block in the rear.
I like what fellow member Frizzle Fry did with his truck on his shock relocation ideas. Allowes a stock length front shock to be used both front and rear.
http://67-72chevytrucks.com/vboard/s...05#post4730005
That way you can use whatever shock you want, a softer shock for better ride or firmer shock for better performance.
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
