04-09-2018, 11:09 PM | #1 |
Tilt Steering column
Who's got a source for switch cover puller j 22708?
04-09-2018, 11:40 PM | #2 |
Re: Tilt Steering column
You can remove the cover with a screwdriver and a hammer, ive done it dozens of times, use your best newest screwdriver with a sharp edge, there is a groove on the bottom I think, cant remember the exact location. Start there then move around. Helps to secure the column is a holding fixture nice and tight. Also use the tilt mechanism to get best access.
You can borrow my puller with a deposit and pay shipping both ways....I would need a $150 deposit.... |
04-09-2018, 11:45 PM | #3 |
Here is one on ebay, I think the only difference is the pressure bolt is shorter, different part number but It might be the same tool.
https://www.ebay.com/itm/N16B-Kent-M...4383.l4275.c10 |
04-10-2018, 12:32 AM | #4 |
Thanks for the offer on borrow. Saw the ebay deal,may go for it.Switch is bad gotta get it out.Paul.
04-10-2018, 06:19 AM | #5 |
Old member
I took mine off without any effort. I twisted and pulled up it came right off.
04-10-2018, 10:09 AM | #6 |
Be nice to get lucky like that,this ones been rebuilt and is tight.
04-10-2018, 11:49 AM | #7 |
Old member
Where the turn signal are tilt switch comes through slip a screw driver in and pry real easy and see if it moves.
