Cab Mounts?
I Bought a Cab Mount Kit and not sure of the placement and Order of The mounts. Some are Thick and others Are thin with Lots Of Washers.. I Took a Pic Of The Kit Layed Out but it wont let me post it..... any Help Would Be Great. Thanks
Posted via Mobile Device |
Its a Truck Thing......
Re: Cab Mounts?
You pic may be too big of a file size. Resize it to under 100KB and it should post.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
#3 | |
Re: Cab Mounts?
There Are 2 Big washers for the Big Bolts And 6 or 8 Smaller Washers For The Smaller Bolts
![]() Join Date: Jul 2016
Re: Cab Mounts?
That is a crappy kit, I bought one of those off ebay and returned it.
You should get a mount kit that is factory style with the molded in metal pieces. I don't think those will last very long at all. And as far as cab mount kits go....I have never seen one that has the proper length spacers, you should compare the spacers to your originals to get a proper torque on the mounts. I also don't think the style you have will allow a proper torque since they are just molded rubber parts. |
Re: Cab Mounts?
please don't use the kit you have but if you do...
Upper right and left are the core support rubbers, the upper spacers are for the core support. The front cab mounts have the larger diameter molded raised register. Those mounts are also only for 1/2ton 2wd, they wont work with 3/4t or 4wd. |
#7 | |
I Ordered An Energy Suspension Kit...
Re: Cab Mounts?
But Still Not Sure Where The Thicker Mounts Go? On Top Of The Frame Body mount Plate But The Front Or Rear?
Re: Cab Mounts?
I also have the energy suspension kit. If its unusable could someone show us the correct set?
Re: Cab Mounts?
The instruction will say how they go. You do have to reuse some of the old hardware.
I had a set of the energy suspension, but decided to go with the better rubber ones. I heard a lot of people say you get squeaks and a little rougher ride in the cab. I purchased a kit from GMC Pauls.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
![]() Join Date: Dec 2016
Re: Cab Mounts?
Classic Heartbeat pickup parts has a quality kit. A bit pricy but like most things you get what you pay for.
