04-10-2018, 11:42 AM | #1 |
Under column wire?
Anybody know what this dark green plug is for?
Is is under the dash column. Came with a toggle switch connecting the two sides but nothing is turning on.....
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
04-10-2018, 11:56 AM | #2 |
Old member
Re: Under column wire?
Look to see if the back up lights are coming on per the schematic. I circled it you will have to down load it and blow it up.
04-10-2018, 12:07 PM | #3 |
Do you have a high res version of this photo that you can send me??
https://www.ebay.com/itm/295742064443 |
04-10-2018, 12:11 PM | #4 |
Reverse lights, your column is missing the neutral safet/back up light switch.
It mounts in the slot on top of the column, part of the slot is shown in your picture. |
04-10-2018, 12:13 PM | #5 | |
Old member
The connection just left of the turn signal connector. 2-Green wires are back up and 2 purple wires are neutral safety.
04-10-2018, 12:15 PM | #6 |
laying low
Andys got it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-10-2018, 12:39 PM | #7 |
Awesome thanks guys. Off to get new toggle switch.
Looks like I am running manual back up lights. |
04-10-2018, 01:11 PM | #8 | ||
"I ain't nobody, dork."
Or just install the NSS/backup light switch on the column and plug it in. Your NSS (purple wires, same-ish type plug) must have a jumper wire in it if it's not plugged in to the column switch.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
04-10-2018, 01:35 PM | #9 |
3 speed trans. With no switch on it yet.
I will look for the purple tonight
04-10-2018, 01:56 PM | #10 |
If it's a manual three speed (on the tree) then all there is, is a reverse switch. The neutral safety switch is only for 3 speed auto columns.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights |
