04-10-2018, 07:49 PM | #1 |
When you need a part and the aftermarket leaves you hanging, core support mounts
We ordered the cab mount kit and it did not come with the core support mounts. So I widdeld out my own.
Having a lathe sitting around comes in handy from time to time. Did the same type of project for some brake and fuel line hangers Having a mill is kind of nice too |
04-10-2018, 08:36 PM | #2 |
Moderator
Re: When you need a part and the aftermarket leaves you hanging, core support mounts
Since I used the Poly cab mounts I was thinking of using these to replace the core support rubber - https://www.ebay.com/itm/Energy-Susp...19.m1438.l2649
Are yours going to be solid mount?
04-10-2018, 09:48 PM | #3 | |
No real benefit to rubber mounting it, will use a small Delrin washer for isolation. |
