Active Member
![]() Join Date: Aug 2003
Seat belt sleeves
Is there a trick to getting the female end through the plastic sleeve? I have been wrestling with this for a while.
Thanks |
Re: Seat belt sleeves
You have to take the other end apart with the spring retractor. then slip it thru and reassemble the retractor.
How did I get this OLD!
![]() Join Date: Dec 2014
I have put many sets on with a heat gun to warm the plastic then tie a wire or string and pull the end through.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
Active Member
Thanks Canuck. Really trying to avoid taking the belt apart.
Active Member
Heat gun worked like a charm took less than five minutes.
Thanks Canuck. |
