Old 04-11-2018, 01:26 PM   #1
Duraburb
Duraburb's Avatar
20x11's?? will they fit?!
Hi guys! Was looking at trying to order up a set of Detroit Steel 8-lug smoothies for my c20 Burb. Was looking at the 20x8 for the fron and was hoping to do their 20x11's for the rear. ANybody have any advice/suggestions on this setup? Backspacing that will work, etc. It's factory 8 lug and will be on air ride . with stock-ish suspension, big c-notch in the rear, factory disc brake front. Thanks for any help!!
1972 C20 Suburban, Bagged and c10 swapped Suspension (sold)
1969 Jimmy, 2wd swapped. bagged, body dropped
Duraburb is offline   Reply With Quote
Old 04-11-2018, 02:09 PM   #2
nastety92
Re: 20x11's?? will they fit?!
I have a 17x8 with a 255 wide tire on my 67 Burb. I can't see how this would fit without cutting the rear floor and tubs. Maybe I'm wrong though.
nastety92 is offline   Reply With Quote
Old 04-11-2018, 03:10 PM   #3
slowcpe
slowcpe's Avatar
Curious on this myself. I've been eying the Delrays for my '72 c10.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 04-11-2018, 03:50 PM   #4
Duraburb
Duraburb's Avatar
I'll be cutting the floor out anyway, so don't mind widening the tubs while I'm at it. My main concern is trying to find a good backspacing
Old 04-11-2018, 03:56 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I tried to figure out what rims I would need to put these tires on the panel Truck. I can't find my notes right now but I had it figured out that I would need 15x11's with a 7.5" back space. My tubs are already widened almost to the frame. I just don't want them sticking out of the wheel wells.....
LockDoc
Leon
Old 04-12-2018, 09:51 AM   #6
Hart_Rod
Hart_Rod's Avatar
20x11's would be pretty tight with stock wheel tubs. I have a bolt in c-notch with bags. I'm running 20x10s (5"BS) with a 295 45 and it's close. On occasion, I get a slight rub on the inner wheel well on the tire bulge if I turn really hard. You would have to be spot on with your backspacing AND get the right tire size with 20x11s.
Hart_Rod is offline   Reply With Quote
Old 04-16-2018, 03:44 PM   #7
Duraburb
Duraburb's Avatar
Thanks everyone for the ideas and suggestions! I'm leaning towards the 20x11's and getting 7" backspacing, as I'm planning on widening the tubs anyway Just want to make sure i clear the outer portion of the fender. Thanks again!
