Old 11-10-2003, 03:35 AM   #1
wxman1
Bending Exhaust Pipe
I'm going to install new exhaust pipes
on my 69 C10 P/U with 350/TH350.
I was wondering if anyone had ever bent their
own pipes?
I've thought about using something like this
that Harbor Freight sells. Any Ideas
Jim
Mt Juliet
wxman1 is offline   Reply With Quote
Old 11-10-2003, 05:10 AM   #2
rage'nrat638
rage'nrat638's Avatar
the only way that i have bent pipe is to use the sawsall and cut a little pie shaped piece out ..bend it back together and weld it up...
worked for me but i have a mig welder...best thing i ever bought..
bender would be nice..but how many times will you use it???
rage'nrat638 is offline   Reply With Quote
Old 11-10-2003, 05:41 AM   #3
Duallie
Duallie's Avatar
That bender is for bending heavywall PIPE, not thinwall exhaust tubing. It does make some excellent kinks, however. Don't waste your time with that bender.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
Old 11-10-2003, 10:21 AM   #4
tim m
Find an electrician with a Greenlee 855. It is a hydraulic bender that works with thinwall and hardwall. The only thing is that mine can only bend up to 2 inch.
1970 k10
1971 C10
Gilbert Az
tim m is offline   Reply With Quote
Old 11-10-2003, 03:24 PM   #5
wxman1
My brother told me about a procedure
whereby you pack the pipe with sand
and then bend it. The sand supposedly keeps
the walls from collapsing. I suppose you could
also make some sort of homemade internal mandrel for the pipe to keep it from collapsing.
Has anybody ever tried this?
Jim
Mt Juliet
Old 11-10-2003, 03:28 PM   #6
lukecp
Formerly yellow72custom
lukecp's Avatar
Summit sells pre-bent sections of exhaust...usually mandrel bent too. So you can use rage 'n rat's advice and cut out the bend you need, then weld it into the section of pipe.
I'm lazy myself....i just go to the muffler shop
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 11-10-2003, 03:41 PM   #7
cableguy0
just take it to the exhaust it will be cheaper and less aggrevating in the end or just do what i did and dont use any thing but straight pipe off the headers with mufflers dumpings just behind the cab. but you can only do this if you have one hell of a stereo and bad hearing to start with otherwise your gonna go deaf
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-10-2003, 07:18 PM   #8
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I have that same setup on mine right now.
I just did it because it was cheap. it cost me 60 bucks to have two pipe bent to tuck up as close to the frame as I could get them and installed. If you don't have a lot of money at the time then go this route but, You WILL end up changing it after a while because it is annoying. Just my .02
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 11-10-2003, 07:22 PM   #9
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
If your not an experienced pipe bender, its better to take it down and have someone do it. Only cost me about $150, but they used my old mufflers.
Cat Fuzz is offline   Reply With Quote
Old 11-10-2003, 07:29 PM   #10
rustyold69
student wrench turner
rustyold69's Avatar
i bent my whole exhaust system in shop class. They have a big hydraulic bender that can take up to 3 1/2" pipe with ease
1969 Chevy C-10 with 250 L6
2002 GMC Sierra 2500 HD Duramax with banks six gun
rustyold69 is offline   Reply With Quote
Old 11-10-2003, 07:40 PM   #11
gr8scott51
gr8scott51's Avatar
pipe bending
I used to bend pipe for the Navy. The sand method works, but it has to be DRY, you have to weld up the ends and then the pipe is normally bent using a torch.
To do a mandrel bend, you have to draw the mandrel out as the bend is made. This is done on a radial bender, using drawing wax on the mandrel. You can't just leave the mandrel in the pipe and cruch it, because you'll never get the mandrel out.
Conduit benders work fine, but there will be some crushing and wrinkling. Even most exhaust places will produce the same results, but they have the tools and experience to fit it correctly.
Having exhaust piping mandrel bent can get pretty expensive and not all shops can do it.
I guess I'd have to agree with the others. If you aren't going in to the pipe bending business, and the pre-bent stuff in the catalogs don't do what you want, take your rig to a muffler shop.
good luck, Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 11-10-2003, 09:50 PM   #12
69sixpackbee
Heat it and beat it.....nuff said
69sixpackbee is offline   Reply With Quote
Old 11-10-2003, 10:06 PM   #13
gonebad2
Merciless Butcher
gonebad2's Avatar
Go to the Summit catalog. They sell a prebent set of pipes made by Hooker. They are specific to your truck. You can order them to be hooked up to stock manifolds or headers. They only come in a longbed version but I cut about 18" out of the middle and workded great. They cost less than $120.00. Mufflers not included. I went with flowmaster delta series.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 11-10-2003, 10:26 PM   #14
oldtrucknut
67-72 truck surgeon
mandrel bent pipes are much better because they don't have those kinks in them that reduce exhaust flow. Mandrel bent pipes really do make a difference in power.
1969 Chevy C10
1993 Toyota Camry LE
1999 Ford F250 Super Duty 4x4 diesel
2008 Dodge Charger Super Bee
1953 International R182
oldtrucknut is offline   Reply With Quote
