Dropping my 70 c10 questions
I Got Some Cpp 2" Drop spindles N Got Them Coated So I Can't Return Them for a 5/7 Static Drop but Now That I've Seen a 6/8 Drop I Wanna Go That Route.. Can I Cut An Inch Off a 3 inch Front Drop Spring or is That Pushing It? Thanks
Posted via Mobile Device |
Re: Dropping my 70 c10 questions
even the 3" spring seems to be cutting it close on some trucks to what we can be effectively aligned. I am very happy with my 4.5" drop using ECE spindles and 2" springs and would go that much again.
IMO, 6" static drop in the front starts to cause driving issues that you just don't see at 4.5".
67-72 parts collector,…
![]() Join Date: Nov 2002
Belltech make a 3” drop spindle. That’s the only way I would try a 6” front drop.
