Old 04-11-2018, 04:47 PM   #1
ga-stepside
ga-stepside's Avatar
Oil pressure port
I am changing the oil pressure gauge to an electrical one. I pulled the copper line off the fitting at the back of the block but it left a brass treaded fitting in the block. There is no hex head or screw driver slot to try to get this out. Any suggestions? Worse comes to worse I could put some vice grips on it but I don't want it to break off. Also from what I have read this fitting is a 1/8" NPT, is that true?
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 04-11-2018, 04:50 PM   #2
Troy Sr
Troy Sr's Avatar
Re: Oil pressure port
Sounds like vise grip time, and yes it is an 1/8-27 NPT.
Take Care
Troy
Troy Sr is offline   Reply With Quote
Old 04-11-2018, 04:59 PM   #3
ga-stepside
Thanks. I don't have a warm fuzzy feeling about this! After all the other nightmares I have found the PO did on this truck he probably glued that thing in!
1967 C10 Step side
1970 AMX 390
Old 04-11-2018, 05:03 PM   #4
HO455
Post Whore
HO455's Avatar
I have never seen one on out trucks but there are fittings that have a hex inside the fitting that allows an Allen wrench to be used to install or remove the fitting. On the bright side if there is no hex anywhere on the fitting I can't be very tight.
Good luck
How about using an EZout or other broken bolt remover? If you did get some brass shavings in the hole you could crank the engine over with the coil wire off and flush them out with oil before hooking the guage line up.
RIP Bob Parks.
Old 04-11-2018, 05:06 PM   #5
Sweeet67
I just replaced mine, you should be able to put a deep socket over the whole thing and back it out. I don’t remember the size though. 3/8ths maybe?
Sweeet67 is offline   Reply With Quote
Old 04-11-2018, 05:33 PM   #6
ga-stepside
We have a winner. I climbed into the engine bay to get a better look at it, cleaned off some crap and sure enough there is a hex. It is a 7/16. It is out. But of course the new sending unit is too big, it hit on a boss on the intake. Either gonna have grind that off a little on that boss or get a right angle adapter.
1967 C10 Step side
1970 AMX 390
Old 04-11-2018, 07:55 PM   #7
Sweeet67
Glad it worked out.
Old 04-11-2018, 08:09 PM   #8
ga-stepside
Glad it worked out.
I fell kind of stupid right now. But as far back as that engine sits seeing in there with my old eyes isn't easy. Plus I can't believe all the stuff I had to take off to get at that fitting.
1967 C10 Step side
1970 AMX 390
Old 04-11-2018, 08:22 PM   #9
Fraud
Can you share what gauge and sender you're using?
Thanks!
Fraud is offline   Reply With Quote
Old 04-11-2018, 08:27 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
Getting old ain't for sissies. I bought a baseball cap with LED lights in it many years ago when I woke for exercise in the morning before going to work. I'm talking about getting up at 3:30 AM, and some streets had no lights. It works sort of OK working on the truck. I'm thinking of getting one of those magnifiers with all the LED lights on it, since the baseball cap doesn't always light up what I want to see.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 04-11-2018, 08:41 PM   #11
ga-stepside
Thanks!
The gauge is a Dolphin, no clue who makes the sender, there are no markings on it. I think I can get a 45 degree male to female and it will work. Just no room back there with the intake, distributor and linkage bracket. The only other place I can possibly use is on the front of the block but I don't this monster sender will fit there either.
1967 C10 Step side
1970 AMX 390
Old 04-11-2018, 08:53 PM   #12
ga-stepside
I hear ya. When I built my Z I would spend 8-10 hours in the garage. Those days are gone.
1967 C10 Step side
1970 AMX 390
Old 04-12-2018, 08:44 AM   #13
sick472
sick472's Avatar
You might consider an "Oil Filter Sandwich Adapter" if you give up on installing the sending unit due to space constraints. They are great for adding oil temp and pressure sensors.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 04-12-2018, 09:36 AM   #14
ga-stepside
Didn't think of that. It's an option, thanks.
1967 C10 Step side
1970 AMX 390
Old 04-12-2018, 11:27 AM   #15
davepl
davepl's Avatar
BTW just for anyone following along, the line should be STEEL and not COPPER. Copper will work harden and leak eventually.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-12-2018, 11:26 PM   #16
TinnMann
I had to re-route my oil pressure sender in my firebird when i build a 350 vortec for it last year. I got some small copper nipples and fittings from the hardware store to move the sender towards the drivers side a little more. It was very tight and quite the headache, but it worked, there is a little more room in our trucks so you should have no problem. (Although the sending unit might not be as accurate if you go too far?) Make sure to use thread sealent on all heavy oil application threads. Good luck!
TinnMann is offline   Reply With Quote
Old 04-13-2018, 07:56 AM   #17
zosoppp
Since the mechanical style oil pressure gauges had a line all the way from the engine into the cab to the back of the gauge, and they "worked" then putting a few inches of line in to move the electrical pressure sensor should not affect the pressure readings.
Temperature gauge senders, on the other hand, should be "in the flow" inside the part they mount to. Too many adapters can move the probe into a dead spot and cause them to potentially read low.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights
zosoppp is offline   Reply With Quote
