Old 04-11-2018, 09:45 PM   #1
CUDA8U
CUDA8U's Avatar
convertingc20 to c10 and lowering
whats involved?
can the rear axles be changed to a 5 bolt pattern?
what has to be changed in the front to convert and lower?
CUDA8U is offline   Reply With Quote
Old 04-11-2018, 10:29 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: convertingc20 to c10 and lowering
What year truck?
www.earlyclassic.com sells a 3/4ton-to-1/2ton conversion spindle.
That would be the easiest.
No ball joints or tie rods to change.
Otherwise you need to change your lower a-arms to the 1/2ton version and start swapping parts from a 71-87 truck.
I assume your truck is 2wd.
Not enough info in your question.
Keith
Convert to disc brakes.
Old 04-12-2018, 07:49 AM   #3
Mike C
Mike C's Avatar
You cannot just replace the axles to get a 5 on 5 pattern on the rear. It will require replacing the complete assembly with one from a half ton donor.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-12-2018, 01:05 PM   #4
demian5
demian5's Avatar
I will send you my paypal information for providing this link to you. I just saved you hours of work and tons of $$.
https://www.airbagit.com/8-Lug-To-5-...ers-s/1591.htm
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-12-2018, 06:28 PM   #5
lolife99
lolife99's Avatar
There is no way I would ever run those type of adapters.
Two piece adapter held together with bolts. NO way.
Keith
Old 04-12-2018, 06:42 PM   #6
CUDA8U
CUDA8U's Avatar
You would think that someone would build a 5 stud axle to change out the 8 bolt for a conversion
Old 04-12-2018, 08:07 PM   #7
Alex V.
Alex V.'s Avatar
Or sell the hard-working C20 to someone who will enjoy it for what it can do, and buy a C10 to slam out hence mostly negating its function as a truck.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 04-13-2018, 08:33 AM   #8
Mike C
Mike C's Avatar
The 8 lug studs are in a hub. The axle has a small flange that drives the hub so the axle is not what needs changing. The 8 lug hub pilot is large like the 6 lug 4x4 and drum hub. It won’t fit in a 5 lug wheel. That combined with virtually zero demand in the big scheme of things.
It’s just too easy to swap in a 5 lug 1/2 ton assembly. But with late model vehicles having 17” and 18” wheels, tons of tire choices so you can keep the 8 lug setup and still lower the truck since 3/4 ton drop spindles are out there now.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 04-13-2018, 09:55 AM   #9
jessemthompson
I think you’d be better suited to cell the C20 and Buy a C10
jessemthompson is offline   Reply With Quote
Old 04-13-2018, 10:22 AM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Seems to me to be the hard way to get a C10. I have watched my stepson do this exact task as he is transforming a 1970 C20 into a C10. He got lucky and found a C20 with factory trailing arms and 3/4 ton coils springs. So he swapped out the ginormous Eaton HO rear end for a 12 bolt out of a 1969 C10, replaced the rear springs with 1/2 ton lowering springs. He replaced the entire front crossmsmber with a 1968 C10 crossmember and added front lowering springs as well. He has gottemn extrememly good deals on the parts as he has been very patient looking around. He got the 12 bolt (with factory posi-traction and 3.73's) for 50 bucks. The 1968 front crossmember was free.
He plans on doing a 5 lug conversion soon. But for now the 6 lug stuff is working fine for him.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-13-2018, 10:30 AM   #11
CUDA8U
CUDA8U's Avatar
Gary
I found a c20 with a rust free body,396 400 auto for $4000. Maybe I could find a rolling frame and swap since I am painting everything anyway.
Old 04-13-2018, 01:08 PM   #12
GASoline71
GASoline71's Avatar
$4,000 grand for a C20... that thing should be almost mint. I'd think of paying 4k for a K20...
That's a lot of money to pay to start swapping things around. I see you're in the land of road salt and ice... so I'm sure most of these rigs are rotten to the core anyways around your parts. Around these parts, 4k can get you a pretty dang decent C10 with minor rust and a decent drivetrain.
Gary
Old 04-13-2018, 02:28 PM   #13
CUDA8U
CUDA8U's Avatar
Gary
yes its near mint,its a southern truck with a complete new interior,rebuilt 396
Old 04-13-2018, 06:33 PM   #14
lolife99
lolife99's Avatar
NICE c10's or c20's are impossible to fine for $4k in Missouri.
I think he OP probably got a good deal.
But can't tell without pictures,...
Keith
Old 04-13-2018, 07:14 PM   #15
jocko
jocko's Avatar
Recommend chat with ledzepp on this.
If it’s that nice and you got a great deal - drive north, sell for profit, buy a nice C10.
Old 04-13-2018, 09:19 PM   #16
Just because you don't appreciate a C/20 doesn't mean someone else won't. Far more C/10s out there. Go buy one. I'd rather see a velour seat than a C/20 degraded. You can lower a C/20 if you want to you know? Not that I ever would.
