Old 04-11-2018, 10:26 PM   #1
boswack
Vin number
Hello all, recently I purchased a 54 5 window truck I was so exited about getting the truck for so cheap I didn't even check to see if vin plates where on the truck or not. I did get a bill of sale . How would I go about registering this vehicle? The vin tag is missing on the door pillar. Anyway with a bill of sale Could i get a new vin somehow? Anyhow if anyone has dealt with this kind of situation before thanks in advance for any suggestions. Might have to just part out the whole truck
boswack is offline   Reply With Quote
Old 04-12-2018, 12:08 AM   #2
Foot Stomper
Foot Stomper's Avatar
Re: Vin number
Location?
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 04-12-2018, 12:15 AM   #3
iowaboynca
iowaboynca's Avatar
Re: Vin number
Q1- Is the original motor in the truck? I assume not...(can research the serial # on the motor for traceability)
Q2- Have you researched what Mississippi will do to title the truck?
See Q2 above...
I did some quick research and it looks like its managed by your Dept. of Revenue (shocking...) See the link.
http://www.dor.ms.gov/Pages/Title-Forms.aspx
Do some homework and i'm sure there's a way!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 04-12-2018, 12:39 AM   #4
boswack
Re: Vin number
Everything I've read requires me to have a vin number... Anyways thanks for the help
Old 04-12-2018, 04:17 AM   #5
Jesse Z
Re: Vin number
Mississippi is one of many states that allow a state-assigned VIN. Take the vehicle to your motor vehicle agent for a VIN inspection. If they cannot locate a VIN, they will assign you a new VIN number and attach the corresponding tag to your truck. You need only supply an affidavit explaining why the VIN is missing. In your case the truck's age alone should constitute sufficient cause.
Here is a link to the MS State Assigned Vehicle Identification Number form:
https://www.google.com/url?sa=t&rct=...0EHEA-j9diBWPC
Here are the instructions; Section B1 (missing) would apply to you:
APPLICATION FOR ASSIGNED MISSISSIPPI VEHICLE IDENTIFICATION NUMBER
ALTERED, REMOVED, OBLITERATED, DEFACED, MISSING, OMITTED, STOLEN
Sections A, B, C and E must be completed if application for a Mississippi Assigned Vehicle Identification Number is for reason that the original plate is altered, removed, obliterated, defaced, missing, omitted or stolen.
A. If reason is defaced, altered, obliterated or removed, the following supporting documents must be submitted:
1. The vehicle identification number plate.
2. Affidavit by owner stating the circumstances by which the vehicle identification number was defaced, altered, obliterated or removed.
B. If reason is missing, omitted or stolen, the following supporting document must be submitted:
1. An affidavit by owner stating the circumstances by which the vehicle identification number plate was missing, omitted, or stolen. If and when the original plate is recovered, it shall be surrendered to this department.
Upon approval of application, a Mississippi Assigned Vehicle Identification Number Plate will be issued. A representative from this department will inspect the vehicle, deliver and attach the assigned Mississippi plate. After the Mississippi plate has been attached to the vehicle, owner must take form 78-602 to a designated agent (local county tax collector, dealer, or bank) and make application for a certificate of title.
Jesse Z is offline   Reply With Quote
Old 04-13-2018, 10:48 PM   #6
fine69
fine69's Avatar
Re: Vin number
Back then so e states used the vin on title, some the engine vin. I have a 49 panel that has BOTH on the title.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
