![]() Join Date: Mar 2011
8X15 RALLIES ALL AROUND tire size
I am going use my 15x8 rallies all away around on my 69 .I want the raised white letter look . I have looked at older posts and still am not confident im going to choose the right size and end up being stuck with tires that rub I have a shortwide or fleet side bed 4-6 drop with a 68 rear which is slightly narrower than the 69-72 . I want to be as tall and wide as possible without the rub
![]() thanks for helping Jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
Re: 8X15 RALLIES ALL AROUND tire size
I would do a 255 60 15 in front and a 275 60 15 rear.
Because, Uh, my name is Dave, and uh... I like to party.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC Last edited by demian5; 04-12-2018 at 01:00 PM. |
laying low
![]() Join Date: Mar 2001
Thats a nice size combo. I have 255/70/15 on 8” rallys all around with 41/2” and 4” drop.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
P275-60R/-15 works.
Thats about the look my 31 1.50 and 11.50 15s give my truck.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
![]() Join Date: Dec 1999
Posted a picture of my truck on the before and after post on 3/11. I’me running 8” wheels. 2/4 drop. 255/60/60 front and 275/60/15 rears. My 2 cents.
Smitty '71 Short Fleetside Spring Valley, Ca. |
Active Member
![]() Join Date: Mar 2018
I need to find me a set of those wheels for my truck.
Previous C10's 69 SB CST - sold 72 Cheyenne Super LB - sold |
![]() Join Date: Aug 2004
I had 15x8 with 275/60’s front and rear on my previous 68. It was lowered about 2/4ish.
Worked well and I was able to rotate tires as needed. I will definitely run this setup again. Pics are in my profile.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
thanks to all looks like 275 60s most popular with you guys do you know how tall they are?
28 inches.
Jess, those wheels look great, with the beauty rings. Did you polish them?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#13 |
I have a square setup and love it.
275/60/15 all around. 28" tall tire. ECE 4.5/6.5 drop. ![]() ![]() ![]()
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
#14 |
yes i did ! thanks Jim, I think they are going to look great on the 69
#15 |
thanks for the PICs your truck is beautiful.... Im convinced 275/60s all around
#16 |
I have the 275/60/15s on 15x8 rallies also and love the look of them.
#17 |
![]() Join Date: Dec 2012
I have them as rears on mine - 275/15/60’s
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#18 |
![]() ![]() Join Date: Mar 2016
I am running 255-70 rear, they are taller than 275-60 and only 1/2" narrower. I am blackwall out cause they didn't have 245-60 for the front in the brand I have on the rear anymore . I did not want two different brands showing.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
#19 |
I have ran 285-70 before without issue.
#20 |
![]() Join Date: Aug 2008
x2 but mine was a 72 stepside (profile photo but later swapped to 20x8's)
#21 |
I still have a set of 15x8 wheel vintique stock style non rally wheels that I had on the same truck. 275 60r15 as well. I was running 67 chevelle "Poverty" caps with stainless trim rings. Same backspace as rallys. No rub anywhere even with 2"/4" static drop
#22 |
#23 |
look great on the stepper
#24 | |
TY Jz
#25 |
![]() Join Date: Jan 2009
Here’s mine 275/60/15 out back and 245/60/15 in the front
Kevin 67 custom cab big window swb 350/700r4 4/6 drop tilt,a/c 69 custom/10 swb 350/350 4/6 drop tach,tilt 71 cheyenne super swb 454/700r4 4/6drop tach,tilt,a/c,bucket seats,speed warning 96 gmc swb ![]() |
