![]() Join Date: Mar 2013
WTB center floor area, t.case Xmember, s.brace
When the previous owner installed a doubler transfer case he cut the center area of my Blazer's floor out and pushed it up in order to raise the Transfer case up 4 ground clearance.
I first put this WTB in the Blazer section but I realize now that I can get by with a high hump section from a truck as well. I need the center area of a H.H. floor from the fire wall to the rear. It may be hard to see but the high hump opening was first cut off then slightly raised up along with the floor area behind it which I now have completely cut out. so thats why I need the high hump area too. If I get desperate I could make a low hump work I guess,after Its welded in I could cut out the opening and add the thread bosses, or maybe just fix the damaged area of my H.hump opening and then I would only need to add the back of the center floor which means any 67-72 floor would work. The good thing is this area is not normally a badly rusted section so if the rest of your floor is trashed this area might be good enough for me. Also Transfer case x member Also I need the center section of the under floor bucket seat brace so if you have one badly rusted I only need a piece of the center to splice into mine see pic. where mine is cut. |
![]() Join Date: Jul 2016
Re: WTB center floor area, t.case Xmember, s.brace
I have that from the 68 GMC C30 I am parting, the truck floor is the same until just past the rear seat mounts, then the blazer is different and your missing part of that.
![]() Join Date: Apr 2000
pm sent
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
