Old 11-10-2003, 09:33 AM   #1
Brently
cargo light dimensions to cut hole in back of cab
my truck does not have a cargo light but i want to put one on it and have recently bought one - does anyone or can anyone give me the correct possible way to cut the dimensions for this light - any help would be appreciated - thanks, Brent
Brently is offline   Reply With Quote
Old 11-10-2003, 10:47 AM   #2
VTKidder
I'm looking for the same info for the same reason.....if we don't hear anything, I'd just measure out what the size of the back of the light is, cut the hole, and fit it as you go. It'd be nice to know the specs though....
VTKidder is offline   Reply With Quote
Old 11-10-2003, 12:14 PM   #3
rickspickuppart
What we did was found a junk cab and cut it out to use as a template.
Shawn
rickspickuppart is offline   Reply With Quote
Old 11-10-2003, 12:45 PM   #4
Brently
cargo light
you wouldn't still have the same template would you? Brent
Old 11-10-2003, 12:48 PM   #5
rickspickuppart
I will go look for it but I wouldn't be able to do much w/ it as far as tracing (my scanner died).
Shawn
Old 11-10-2003, 01:16 PM   #6
Brently
cargo light
maybe you could give me the dimensions of it? measurements from hole to hole or cut out? thanks
Old 11-10-2003, 03:18 PM   #7
Mudder
Mudder's Avatar
Its a lot smaller than the size of the cargo light I know. My body man cut mine out. Seems if I remember right its more like a slot that you cut out.
Mudder is offline   Reply With Quote
Old 11-10-2003, 03:59 PM   #8
VTKidder
From what I remember, seeing a couple of them, , there is a hole for each screw, then a half circle on the inside of the screw hole where you can slide in one of those threaded sheetmetal clips that will hold the screws in place, then about a 2"x1" hole for the butt end of the light and wiring to fit into....
Old 11-10-2003, 05:28 PM   #9
Dean
Dean's Avatar
It seems to me like the dimensions might be in the assembly manual if you have one. It has been awhile since I put one of those in.
Dean is offline   Reply With Quote
Old 11-10-2003, 07:31 PM   #10
gregsplace
gregsplace's Avatar
1 3/8 X 4" hole, 5 5/16 between screws( on center)
67 3/4 4x4 402,a/t,flat bed
98 GMC Sierra swb daily driver
87 burb parting out.
68 1/2 chevy, 350/350, 71 gmc frame, kid's beater
69 1ton 396-4sp, dump
69 swb stepside 396/400th current frameup
67 swb 454/400th rebuilding now, oldest boy just rolled it
99,HD, Road King Classic
Colwich Ks
gregsplace is offline   Reply With Quote
