Old 04-13-2018, 03:22 PM   #1
Swatson
66 Chevy c10 ignition switch removal
I'm trying to remove my ignition switch to take the cluster out, and the pin in the ignition won't push in. Any tips?
Swatson is offline   Reply With Quote
Old 04-13-2018, 03:50 PM   #2
Ken Cook
Ken Cook's Avatar
Re: 66 Chevy c10 ignition switch removal
This is what I did.
https://www.youtube.com/watch?v=_Th8f6yoCcA
Ken Cook is offline   Reply With Quote
Old 04-13-2018, 03:57 PM   #3
VetteC10
I did the same, just need to have a strong pin to push it in with. I had a very small screw driver that I used.
VetteC10 is offline   Reply With Quote
Old 04-18-2018, 07:31 AM   #4
Swatson
I've tried to do the same as in the video. I'm using a small screwdriver and no matter how hard i press in, it never gives or anything. My ignition looks a bit different, flat face and only one hole. I assume its the same process to remove it, do have to have the key turned a certain way to depress the pin? I've had it straight up and down, and it'll only move right to maybe 1 O'clock and then to 3 O'clock.
Old 04-18-2018, 08:33 AM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
I used a pick or awl to do it, takes finesse for me to get it, doesn't just pop out.
