Signal lights
I have put a new led lights in my truck and now the signal light does not work. do i need a different blinker?
Re: Signal lights
Which light are you talking about? One of the ones outside of the truck or the one in the instrument cluster?
Re: Signal lights
Re: Signal lights
it will turns on, but they do not blink
Re: Signal lights
The flasher will cause them to come on but not flash back off. The don't draw enough current to make it trip.
Re: Signal lights
ok, what should I do?
Re: Signal lights
Get a new flasher that is for LEDs. They are usually a clear plastic with the same connection. Your local parts store should know what you need if you tell them you installed LED lights. I think the flasher is a solidstate flasher, it has a chip to do the flashing instead of points.
Re: Signal lights
It looks like this. but as long as it has the same connection, it should plug in like the old part.
https://www.ebay.com/itm/2-Prong-Ele...1aL30B&vxp=mtr |
Re: Signal lights
Thanks.
