04-14-2018, 06:24 PM | #1 |
ep240 pump good enough?
I have an ACdelco ep240 pump, with only a few miles on it. This was installed as an upgraded TBI pump, but then I changed direction, and am going with a LS motor.
I've gotten conflicting data on whether the ep240 will support a stock(325-ish hp) LS motor long-term. Some folks say the ep240 will easily handle a LS, others say it won't. Should I pony up the cash, and replace that pump with a ep381? Or would it be a waste of money? |
04-14-2018, 06:51 PM | #2 |
Post Whore
Re: ep240 pump good enough?
i used a walbro 255 on my lq9..makes 344hp..no issues
im not sure it compares to yours
04-14-2018, 08:35 PM | #3 |
From what I can find, the ep240 only outputs ~51 psi, thats not enough for an ls, they need 58. You could probably make a 5.3 run on that pressure but it would need tuning work to do it. Cheaper to buy the higher pressure pump.
04-14-2018, 09:39 PM | #4 |
Post Whore
I just found this on jegs...its says 94 max psi....http://www.jegs.com/i/ACDelco/065/EP240/10002/-1
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 04-14-2018 at 09:53 PM. |
04-14-2018, 11:22 PM | #5 |
Well, max pressure isn't working pressure, who knows how little flow it would have at that pressure. Its also only rated at 15GPH flow rate, which is only good for ~180HP. Far too little for any ls engine.
04-14-2018, 11:28 PM | #6 |
Post Whore
I had to go search what my walbro is cause I couldn't remember....its 67 gph
