Old 04-14-2018, 10:34 PM   #1
Zach Jaynes
How much drop?
Without "bagging", approximately what is the maximum amount of drop that you can get on these trucks without any major negative effects? 5/7 or more than that? Next question, I'd like some opinions on what the best way/kit/etc.. is to achieve this lower ride height. From what I understand, drop spindles (which of course I assume will be a part of the equation) will require converting to disk brakes, which I'm in favor of anyway. I'm about to start my first project. A '69 C10. I'm planning to start with lowering and replacing most of the suspension/steering components while I'm at it, (wear items= bushings/ball joints/tie rod ends,etc...)
Thanks in advance.
Zach
Zach Jaynes is offline   Reply With Quote
Old 04-15-2018, 07:02 AM   #2
panhead59
Re: How much drop?
Best advise I can give you is use the search engine on this site. You will learn moore, faster. Get some parts catalogs. Most are free and easier to use than the online duplicates. Plus there are board members here that sell parts. Searching site will give you pics of different drop heights, then you can deccide. I just did a CCP drop kit and am happy with it. There are some good complete kits out there to do a drop, front disc brakes, and then I went with new power booster and master cyl. It's all about how far you want to go and how much money you are willing to spend. Main thing is, keep it fun, cuz=z= that'll keep it going.
panhead59 is offline   Reply With Quote
Old 04-15-2018, 09:06 AM   #3
Jacoby
Re: How much drop?
Not sure the lowest you can go but I went with a Grand Slam kit from CPP because it was the most complete kit I could find.
Jacoby is offline   Reply With Quote
Old 04-15-2018, 09:33 AM   #4
jessemthompson
Re: How much drop?
I have a 4-6 drop on my truck. 2” spindles, 2” springs up front and 4” springs with 2” drop blocks in the rear. I have NO rear C notch. It is close though. Some people claim 7” drop in the rear without a notch, but personally I wouldn’t go another inch on mine without one.
jessemthompson is offline   Reply With Quote
Old 04-15-2018, 09:56 AM   #5
panhead59
Re: How much drop?
A 4/6 drop was enough for me. A lot of pics here and in parts catalogs of different drops. Just "search" and you'll find em. Most say anything over a 6 in. rear drop and you must c-notch frame. A couple ways to do that.
Old 04-15-2018, 03:31 PM   #6
CUDA8U
CUDA8U's Avatar
Re: How much drop?
some pics may help him with recommendations/tips and which manufacturer.
CUDA8U is offline   Reply With Quote
Old 04-15-2018, 05:05 PM   #7
BugzC10
BugzC10's Avatar
Re: How much drop?
I did a 4.5 / ~6” drop. However I did not like the ground LCA clearance in the front, so I went with a taller tire.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 04-16-2018, 10:14 AM   #8
Haligan34
Re: How much drop?
Early classic enterprises 4/6 great people, also have their rear trailing arms
Haligan34 is offline   Reply With Quote
Old 04-16-2018, 04:58 PM   #9
BossHogg69
motor exploder
BossHogg69's Avatar
Re: How much drop?
^ Nice truck Haligan34!!
Without a notch in back I wouldn't want more than 3/5, just to avoid the occasional big bump and bottoming out in the back. 4/6 & 5/7 looks really good on these trucks in my opinion, but after 4" in the front the LCA clearance gets sketchy with a stock crossmember.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 04-17-2018, 11:04 PM   #10
CUDA8U
CUDA8U's Avatar
Re: How much drop?
absolutely perfect stance and tire combo
Old 04-18-2018, 08:08 AM   #11
Bennett68C10
Bennett68C10's Avatar
Re: How much drop?
Beautiful truck!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 04-18-2018, 10:50 AM   #12
Haligan34
Re: How much drop?
Thanks for all the kind words
Old 04-18-2018, 10:56 AM   #13
BossHogg69
motor exploder
BossHogg69's Avatar
Re: How much drop?
you might as well give us the wheel & tire specs since you're online!
Adam
Old 04-18-2018, 11:19 AM   #14
Haligan34
Re: How much drop?
Its a little deceiving in the photo, because it has 4 steel ralley's with tires in the bed so it's about 3/4 to 1/2 of an inch lower than normal. I would like to drop the rear a little more so it sets like the photos, but not without a notch.
Drop- ECE 4/6
Wheels- 20x8 front, 20x10 rear
Tires 255/40r20 front, 295/40r20 rear
Old 04-18-2018, 03:52 PM   #15
darrellyates
Re: How much drop?
Thanks in advance.
Zach
Kind of depends on the wheel/tire combo you're running. I never worry about the amount of drop, I just want the wheel well full of wheel/tire. I started with a 2 1/2 / 4 inch on my last C10, and then kept going down. Wound up with -5 springs and 2 inch blocks on the rear, and another -1 spring on the front. Was too low. It didn't drive as good as when it was 2 1/2/4 drop. I'll post up a picture. The drop on the Scott's frame is -7. Of course, there is a lot more adjustment in the coil overs on the Scott's frame, so not sure how accurate that is.
Blue/White truck is 2.5 / 4 drop. Gold/White is -7.
darrellyates is offline   Reply With Quote
