Old 04-15-2018, 10:54 PM   #1
twoskies
twoskies's Avatar
internal regulator alternator ?
Good Evening
1972 C10
got a couple questions about wiring for an internal voltage alternator, ive already got the alternator, it is on the passenger side as opposed to the original drivers side(79 el camino complete motor)
heres the question
ive seen 2 different ways to wire from the 4 pin clip to the original regulator
1st way is to jumper or splice the 1 and 4 wires ( brown and blue) together and run the blue wire to the #1 on the alternator, then to connect the red wire #2 off the clip to the #2 on the alternator with a new wire
the original red wire that attached to the battery post on the alternator still goes to the same in both scenarios
2nd way ive seen is to run a jumper on the clip to the brown and the white(#1 to #3)and jumper the red wire to the blue wire (#2 to #4)
and then run the white\brown wire to term #1 on the alternator and run the blue\red wire to term #2 on the alternator
i do have a guage dash, not lights if thats a concern
which is the best way ?
just dont want to burn anything up
appreciate the responses
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 04-16-2018, 12:33 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: internal regulator alternator ?
If you read your description you'll realize that both ways are the same, the only difference is the color of the wire that goes to no. 1 and no.2. on the alternator
You are still connecting the brown wire to no.1 and the red wire to no.2.
I have mine on the passenger side also and here's how I did it.
I bought an adapter from Autozone to plug into the alternator that looks like this.
I don't remember if I had to swap the red and brown wires in the plug to match, but I don't think I did.
Some guys on the internet tell us to wire the red in a short loop from no.2 to the back of the wire on the alternator where the large red wire goes. It will work but it doesn't compensate for voltage drops downstream from the alternator and increase it's output accordingly.
This is how mine looks.
Name:  temperature gauge 008.jpg
I re-clocked the alternator so that the plug was on the bottom for a cleaner look.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-16-2018, 06:57 AM   #3
Myoldtruck
Myoldtruck's Avatar
You can also buy the premade kit to do away with the regulator from Lmc. I went that route. No problems so far.
Myoldtruck is offline   Reply With Quote
