Old 04-16-2018, 11:30 AM   #1
coolfool_2
Manual to Hydro Clutch Pedal Linkage Question
Who has converted their manual clutch to hydraulic clutch? What did you do for pedal linkage? Recently swapped my '61 235 for a 250 and set it up with a Novak slave cylinder kit and Wildood master as I converted to disc and got rid of the single reservoir system. Having trouble coming up with something to get from my clutch pedal arm to the MC all while keeping correct geometry. Thanks in advance.
coolfool_2 is offline   Reply With Quote
Old 04-16-2018, 11:44 AM   #2
sirJim
Re: Manual to Hydro Clutch Pedal Linkage Question
Captain Fab has a great setup! Works great.
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 04-16-2018, 11:46 AM   #3
LVPhotos
LVPhotos's Avatar
I used Cpt coversion.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 04-16-2018, 11:48 AM   #4
coolfool_2
Thanks for those pictures. Does he sell the pedal linkage as well? I know he makes the master cylinder mount kits when using a brake booster.
Old 04-16-2018, 12:07 PM   #5
sirJim
Here is the link to 60-62.
http://www.67-72chevytrucks.com/vboa...d.php?t=362375
Old 04-16-2018, 12:19 PM   #6
sirJim
This is a novak setup on the 283
Old 04-16-2018, 01:11 PM   #7
dieseldude4bt
I used a '63 brake master cylinder and a '62 slave cyl on a bracket from A/A, (both 1" bore) and a pedal assembly from a '62 to convert my '63 to hydroboost and hydraulic clutch.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
