Old 04-17-2018, 09:26 PM   #1
Rick Bollinger
Th400 kickdown
Sorting out a bunch of issues with my 68. One of which is no power to the kickdown on my th400. I installed a elderbrock nitrous switch on the elderbrock carb went right on seems like a great product. Now to find power for it. Will the power from the electric choke wire be sufficient for both? Or can I take it from the hei distributor wire? How much current does it require? I do not want to draw too much from any one item.
Thanks in advance.
Rick
Rick Bollinger is offline   Reply With Quote
Old 04-17-2018, 09:35 PM   #2
HO455
HO455's Avatar
Re: Th400 kickdown
Assuming that this was not a turbo 400 truck to start with?
RIP Bob Parks.
Old 04-17-2018, 09:55 PM   #3
Rick Bollinger
Re: Th400 kickdown
I believe it was but not for sure. I know it has not had power there for years I hope it still works. I am thinking when the PO did the carb swap he did not hook up a switch for the kickdown. Also the electric choke has not worked for quite a while but there was power there and I have a new thermostat for it.
Old 04-18-2018, 01:31 PM   #4
demian5
demian5's Avatar
Re: Th400 kickdown
Get a gas pedal from a 71 or later, the kickdown switch mounts there and gets it out of the engine compartment.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
