Old 04-17-2018, 09:41 PM   #1
reb162
reb162's Avatar
Conversion to 88-95 serpentine question
So, in preparation for my crate engine, I made the decision to go with an 88-95 Chevrolet truck serpentine system rather than the original multiple belt setup.
I got the brackets and mounting bolts off ebay for a 1995 Chevrolet C1500. It came with no tensioner or idler pulley so I purchased those for a 1995 c1500.
ACDelco 38108 Professional Automatic Belt Tensioner and Pulley Assembly
ACDelco 15-4957 GM Original Equipment Drive Belt Idler Pulley
On the bracket with the belt tensioner (P/N 10118751) the idler pullet fits fine, but the belt tensioner appears to have an issue. The bolt hole in the tensioner appears to be too large. The bolt measures as a 12mm 1.75 thread bolt and threads into the bracket just fine. However, the bolt is very loose in the tensioner, more than I'm comfortable with. Anyone else have this issue. Was there originally a sleeve in the tensioner?
The bolt mics at 10.79mm at the shank where the tensioner would mount. The hole in the tensioner mics at 14.21mm
Any ideas? Do I have a mismatch in parts somehow (all part numbers check out good for 1995 c1500 by my checks). Am I missing a sleeve?
Appreciate any help.
1971 Chevy C-10
Currently is rust repair
reb162 is offline   Reply With Quote
Old 04-17-2018, 10:23 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Conversion to 88-95 serpentine question
You need an adapter
Old 04-17-2018, 11:35 PM   #3
B. W.
B. W.'s Avatar
There should have been a sleeve in the box. Not all tensioners use the sleeve. (different manufacturers) FWIW, I'm using a '94 serp setup & using the tensioner in the pic. It doesn't really matter but I like the looks of the OE tensioner better.
B. W. is offline   Reply With Quote
Old 04-18-2018, 08:21 AM   #4
reb162
reb162's Avatar
I figured there had to be a sleeve, and of course there was none in my box. I also bought oem. Out of curiosity, what part number did you buy? I guess I need to return mine and get one with a sleeve or try to find a sleeve.
Bob
1971 Chevy C-10
Old 04-18-2018, 11:18 AM   #5
B. W.
B. W.'s Avatar
OK, I just pulled an old tensioner out of my junk pile, it's an original GM tensioner that I replaced a couple of weeks ago. It measures the same as yours & it had no sleeve. I think you fine running it without a sleeve. The pin on the back locates it, all the bolt does is provide clamping force. (A little slop never hurt any one - - loose is fast!)
Old 04-18-2018, 12:31 PM   #6
Artofdeath
Artofdeath's Avatar
Ha, spoken like a drag racer!
Artofdeath is offline   Reply With Quote
Old 04-18-2018, 01:05 PM   #7
Bigdav160
Bigdav160's Avatar
I thought the bolt had a shoulder, under the head, to keep it centered.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-18-2018, 06:22 PM   #8
reb162
reb162's Avatar
The bolt does have a larger shoulder, but I believe the top area of the tensioner where the bolt goes in is also wider. I'll mic the bolt and top of the bolt holes tonight and post pics and measurements. I tend to agree that maybe there was just meant to be slop. The locator pin really helps to center the tensioner a bit, and then the bolt just is a tension bolt to hold it on.
1971 Chevy C-10
