Old 04-18-2018, 07:24 AM   #1
87 Burb
Oil cooler on 1987 suburban
A mechanic friend of mine, says to eliminate the oil cooler on my 87 burb (350/2wd) that they're notorious for leaking.
My question is two part;
1, opinions on removing or running?
2, if we remove it, do i need another filter mount, or does it seal against the block? There'sa lot of contradicting information out there.
Thanks for any advice you can share.
87 Burb is offline   Reply With Quote
Old 04-18-2018, 11:43 AM   #2
kwmech
Re: Oil cooler on 1987 suburban
If you want to remove it then it comes all the way off, which means removal of the filter housing at the block. Then need the small piece (filter adapter) so you can screw the oil filter back on.
Old 04-19-2018, 12:47 AM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Is it leaking now?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-19-2018, 01:25 AM   #4
kwmech
Is it leaking now?
Good question, I'm on my 2nd 'burb and 3rd square body ('burbs included), all had oil coolers with no leaks other than old hoses.
Old 04-21-2018, 10:15 PM   #5
65panhed
I have an 86 4x4 bourbon and the hoses are leaking now. I'm gonna leave my oil cooler. It's there for a reason.
65panhed is offline   Reply With Quote
