68 air cleaner
I have a 68 with an in-line 6 cylinder 292. I just added a power booster master cylinder setup and I am now running into issues with the air cleaner not fitting, it hits the power booster. Has anybody else run into this issue and if so what remedy did you come up with?
1966 Custom Cab SWB SBW Fleetside 1968 C10 BBW SWB Fleetside |
you need an offset air cleaner. search on this site and there is pictures of the pieces you will need. Good luck. Have a good one eh!
![]() Join Date: Dec 1999
Re: 68 air cleaner
I thought I had a better picture. But a previous owner of my truck cut a piece out of the cover and then welded/brazed a concave piece into the base of the air cleaner.
It doesn't go in far enough to interfere with the actual filter. ![]() |
that set up will probably work ok, it just looks a little off if you get my drift. It all depends on how fussy you are. The offset filters are not that common on the open market but can be found. Keep checking parts for sale, one will come up.
laying low
![]() Join Date: Mar 2001
Re: 68 air cleaner
Here is a pic a member posted a few years ago. It may be a 250/6. I'm not sure but that appears to be an aftermarket master/booster and as you can see it barely clears the air cleaner.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#6 | |
![]() Quote:
#7 | |
Re: 68 air cleaner
If you notice in my picture above, I have a 3/4 booster and master on my 1/2 ton truck. The brakes work amazing, but lock up the rears in an instant. |
Re: 68 air cleaner
Thanks.
Re: 68 air cleaner
I just ran into the same problem. I'm going to use a 6 1/2" aftermarket air cleaner until I find something better. My 10" won't work. I have room for 8" diameter but I haven't found one close to that size. Some of the oblong ones might work but they're a little pricey for me.
