04-18-2018, 05:44 PM | #1 |
1967 K10 Drum to Disc Brake Conversion
Need to upgrade my Dana 44 closed knuckle DRUM brakes to a disc brake set up. Any one have some ideas ?
I know I can buy plate adaptors for my 12 bolt. But havent found much information on the front |
04-18-2018, 06:55 PM | #2 |
Re: 1967 K10 Drum to Disc Brake Conversion
Most people will tell you to find a later model axle to install under the truck.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
04-18-2018, 09:10 PM | #3 |
Yep, what Big Dave said. The cheapest / easiest route is a '71 or later D44.
04-18-2018, 09:19 PM | #4 |
I wonder up to what year is the right fit ? 71 to ??
04-18-2018, 09:24 PM | #5 |
'91 in Suburbans and Blazers. 1987 in trucks. Somewhere around 1980 they switched from the Dana 44 to a 10 bolt Chevy in the front and from the 12 bolt to a 10 bolt in the rear. Six of one, half dozen of the other IMO.
There are some caveats for you. If you get a Dana 44 you can swap your gears into the open knuckle housing. But if you buy a 10 bolt unless you have fairly common gear ratio of a late model truck, you will need to buy new gears and have them setup. I wouldn't waste my time on the 12 bolt discs. The drums are more than sufficient in the rear. If I was doing anything, instead of just a front swap I'd swap front and rear from a 3/4 ton truck. The semi-float 14 bolt and 10 bolt front from an early 80's through '91 Sub is a great swap that gives you significantly more powerful brakes. I did this on my Jimmy with a factory set of 4.10 from an '86 Sub with HD towing package. We are doing it on my kids Jimmy with 3.73 axles from an '84 sub.
08-27-2018, 09:38 AM | #6 |
I'm Planning on the same thing.
69 GMC K10. Found a front end off a 78. Same ratio. What kind of mess I'm I going to find with the steering components? Do I need to install a break booster now that I have discs? |
08-27-2018, 09:56 AM | #7 |
You don’t HAVE to convert to power brakes when you install disks, but I certainly would do it while you’re doing all of this to your truck. You’ll be glad you did.
