Finishing Static drop
When is low to low finishing up the suspension doing static drop, have to stay in what budget , kind of surprised how low this turned out have done several 67-72 but first time for this gen, have 4.5 inches at cross member in Upstate NY this is marginal with heaved roads and potholes going to give it a try see how goes
Re: Finishing Static drop
Looks good to me.
4.5 at the cross member gives you about 2.5 at the LCA. That's too low for me.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
![]() Join Date: Jan 2011
There is still 300 pounds to go on that truck. It will be bottoming out. Whats in it for parts on the drop.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
The 4.5 was with 2 guys on the front rails have 2.5 front drop spindles I coil off front springs drop rear springs with all parts including manual dual master and proportioning valve rotors bearings seals calipers hoses pads and misc pieces have $425 all in don't think that is to bad for all new parts
I see you have gone with a crate engine. Good choice. Ride height looks good.
haha on the crate , weather has been crappy here snowed yesterday says some for tommorow have car in garage on lift that needs work so covered engine dont want to leave outside but no choice for couple days , on the engine though found a 307 bored .40 over done top to bottom balanced nice cam only run to break cam in ,and a th350 all rebuilt 2200 stall convertor and shift kit have $1000 all together, low buck not a ls motor want a good driver go to some shows but not to show because we use them
#8 | |
![]() Ride height is lookin' good. How much suspension travel do you have before the inner fenders bottom out on the tires? I'm fighting this issue on my '68 right now. I am in the process of putting it all together and will have 2" of travel before my fenders bottom out. I'm thinking I need to remove the inner fenders and possibly modify the fenders for more clearance. Maybe even relocate the hood hinges.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
I ran my '66 with 215/75-15's up front and had about 1.5" of travel before it hit the inner fenders. The crossmember/LCA's would occasionally bottom out over really rough spots. Go with a stiffer gas shock to help it from bottoming out as easily. Mine still rode as good as stock with relocated KYB Gas-A-Just shocks up front.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#10 | |
Thanks! 2.5" spindles with 1.5 coils cut off the original springs up front, rear had 1.5" drop blocks and I bought the springs used so I'm not sure the exact drop amount. They were supposed to be 5" but I'm pretty sure they were only 3 or 4". There's a ~220 pound crate in the bed in that pic, so go with 5" springs and 2" blocks to match that look.
#12 | |
Posted via Mobile Device |
#13 |
#14 |
Ece 4/6 drop
At my worst I'm at my best |
#15 | |
#16 | |
#17 | |
#18 |
#19 | |
#20 |
5 inch up front. 7 in the rear. 18 inch wheels.
#21 |
